Results 211 to 220 of 1620
August 28th, 2006 01:04 AM #211
Not that different from installing a 'hotter' chip or ECU on gas engines.
August 28th, 2006 01:08 AM #213
Supposed to increase power via changing the engine settings which used to be under the 'stock' ECU programming.
August 28th, 2006 01:17 AM #215
I'm not a fan of those things. The engine makes good power as stock.
I do not want to compromise driveability or reliability. Some chips are designed to make all out power at the expense of those two.
- Dec 2005
- 207
August 29th, 2006 02:17 PM #216hi guys! we are still waiting for the hilux with abs na. by mid sept siguro makukuha na namin.
uhm may question po ako, may nag upgrade na sa inyo ng tires and rims? kasi nag bibinata ang tatay ko and gusto ng blings hehehe...
ano ba ang size dapat ng tires sa 20's for Hilux? aspect ratio and yung width the tires? salamats!!
August 31st, 2006 09:46 AM #218
check out this site:
http://www.miata.net/garage/tirecalc.html
you can calculate what rubber size you need for the rims you are planning to install. try to install something that has almost the same size as the stock para less modification(on suspension etc.) and minimal impact on you car's intrument panel accuracy(like speedometer).
- Dec 2005
- 207
August 31st, 2006 10:38 AM #219
gusto ko nga yun pero tatay ko kasi hardcore toyota fan yun hehe
nag inquire na ako sa 20's daw dapat mga 60 to 45 series tapos 285 ata.
i saw a fortuner here sa village namin naka 20's and imo bitin pa. kaso sasayad na sa fender kapag niliko mo. so better get mudtires nalang hehe.
September 17th, 2006 07:12 PM #220
http://www.4x4.ie/stock/05hilux2.5silver.htm
saw this on the net. its a 2.5D4d turbo intercooler. 130BHP. totoo ba ito? diba walang intercooler ang 2.5 variant nito?
Traffic!
