Results 551 to 560 of 2000
November 11th, 2011 12:06 AM #551
I'm using Cobra alarm for 1 year w/o any problem. I don't like the chirp parang ibon. Also check kung pag nagopen ka ng door chirp ng chirp hanggat di mo sinasra yung pinto. Pinapalitan ko yung samin cobra rin pero ibang model. Pag nag open ng door hazard light lang umiilaw. You can also check Autopage Alarm
November 14th, 2011 11:59 AM #552
- Nov 2011
- 46
November 20th, 2011 01:37 PM #553I'm also considering to change my 2wk old GL with fortuner 16" rims + 215/65/r16 tires. Pde kaya yun goodyear wrangler hp aw with load capacity of 98H? Ok din ksi review nya at matagal daw mapudpod. may offer sakin na bridgestone dueler ht 235/60/r16 load 100H, P6.5k /pc.we tested it with the rims,wala naman rubbing.I'm just a bit concerned na baka masyado malapad that could lead to higher FC. What other tires would you recommend? Thanks!
November 20th, 2011 03:34 PM #554
Kung wala naman rubbing, ok na yan kung wider. Mas grippy siya. So mas stable, in a way.
- Nov 2011
- 46
November 21st, 2011 12:41 AM #555A shop is offering me Goodyear Wrangler HP AW 215/65/r16 at P5k per tire. I'm more inclined to get goodyear over bridgestone since mas maganda feedback/review.what bothers me is the load index of 98H. Would it be good enough loading 11 pax in a GL model? Thanks!
November 21st, 2011 09:35 AM #556
That is a good price, better check the date of manufacture of the tire to be sure its still fairly new stock.
IMO, the load rating should be good enough for a Grandia with the usual passenger load. Its still within light truck standards lest you really pack it up with passengers and cargo at the same time.
- Nov 2011
- 46
November 21st, 2011 10:24 AM #557
November 21st, 2011 12:26 PM #558
That should be good, the stock 8-Ply Bridgestones are really built for light trucks carrying a good load already and this contributes to making the ride harsh just as well. If you noticed, the Super Grandia variants use the same Goodyear h/t tires which are 6-ply as well.
- Nov 2011
- 46
November 22nd, 2011 11:51 PM #559is it normal hindi ganon ka responsive ang steering?
i'm not sure if nasanay lang ako sa steering ng honda (crv 04/civic 08).
how do you find your steering response?
November 24th, 2011 10:02 AM #560
How do you say by "not responsive"? When you turn while the car is running, the car takes time to react or there's a lot of play on the steering? If its the former, the Hiace is really going to understeer as compared to your Civic and CRV due to its suspension/chassis dynamics and higher center of gravity.
doc, in first world testing kahit walang itim na usok eh bagsak talaga diesel remember the...
LTO accredited emission testing centers
