Sa super grandia lang yata pwede yun if im not mistaken.
Hindi lang siguro cut. Kasi naka bolt yung frame sa flooring diba? Conversion na siguro ginawa. Si seatmate siguro kaya gawin.
mga grandia owner..normal po ba may black smoke ang grandia ntin pag over 3500rpm ang rev niya..lalo na pag nag shifting ng tranny..
Try to use 2T every time you load up with diesel
Given the mileage, you have to check the belts if due for replacement na...kung may loud shudder, pwede ring mga engine or transmission support...
mr cb,
thanks...yeah saw the thread about this and looking to apply it as well
mr mateo,
well noted your points. will look into this. thanks!
also check if kailangan na ba mag tappets adjustment. im not sure if self adjusting tappets ba or hindi yung engine niyo e
Hi guys i have a 2012 super grandia with stock bridgestone tires. Im putting 38 psi fromt tires and 42 psi rear tires. I find the recommended tire pressure too stiff or hard. Whats the tire pressure in your super grandia? Thanks
For my new/old 2005 super grandia, 35 on bridgestone tires are rock hard...i lowered it to 32...
^Hehe... in relation to the Starex?Pero mas maalog pa rin yung ride.
