Results 1 to 5 of 5
- May 2012
- 26
August 23rd, 2014 12:31 AM #1Good day po mga sir i just want to have some input about my gli problem kasi po recently bumabagsak po ung rpm ko on idle state pag mainit na yung makina ko especially po pag naka ON yung aircon ko to the point na namamatay po sya lalo na pag na traffic po ako kaya kailngan kong habulin ng gas pra umangat ulit yung rpm ko tapos after a minute or two babagsak ulit sya, nangyayari lang po ito pag mainit na yung makina ko, one mechanic already clean my throttle and also check my TPS and IAC valve, pati po servo nilinis nya rin po but still bumabagsak pa rin po yung rpm hanggang mamatay sya baka po may suggestion po kayo na pwedeng i-pacheck ko.. salamat po in advance..
- Jun 2014
- 2
August 23rd, 2014 11:30 PM #2
- May 2012
- 26
- 52,701
August 24th, 2014 09:29 AM #4pag malamig pa ang makina, gumagana ang choke (carburator) or idle-up (EFI), para hindi mamatay engine.
kapag mainit na engine, patay na choke or idle-up. ang gumagana na ay ang main circuit.
so, there must be something wrong with your main circuit.
in my old eccs sentra, it was just a problem of the air bleed screw being too closed. it took only 3/4 turn to open it..
- May 2012
- 26
August 25th, 2014 02:16 PM #5salamat sir dr. d i will check that po.. by d way efi po ung corolla ko..
