Page 99 of 179 FirstFirst ... 49899596979899100101102103109149 ... LastLast
Results 1,961 to 1,980 of 3575
    Nov 2011
    #1961
    Thanks for the info sir,very helpful
    Nov 2011
    #1962
    Hello guys, thanks for the very helpful info! Noted po lahat. Also, stay safe dami baha today
    Nov 2011
    #1963
    Quote Originally Posted by MrSn_Kai View Post
    lots of big potholes along the highway in pangasinan. if you're riding on low profile tires, i suggest you use your stock mags
    Thanks again for the info sir
    #1964
    Quote Originally Posted by jhnkvn View Post
    OT: Anong bad experience mo sa HSBC? We used to abuse those Starbucks slips :O
    That's the only time i'd get Starbucks. hehehe... cheapskate.
    The problem i had with the HSBC/Caltex promo was the lack of coordination and clear guidelines disseminated to Caltex dealers (and to the gas boys or cashier). Several times i was refused at some stations because they did not recognize the charge slip (but the same was accepted at another station, and cleared with HSBC when i called). You also get the second rate feeling treatment when you try to redeem; i guess it doesn't help that i usually used the promo to load up our "old" Sentra. Stressful given there were times i went out of my way just to pass by the Caltex station. There's another reason but i can't recall anymore.
    I just found out na casa inflated my tires from 30 to 33. Kaya pala it runs better. Pero nakaindicate sa car 30. Can I make it 33 instead? Is it bad for the tires?
    That's quite okay. I run 35 or 36psi (cold) on mine right now. Hate the soft feeling. At 36-37psi, i already realized some slight km/L gains on my FC.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    "Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth."
    Aug 2013
    #1965
    mga bossing, ano po yung included na default accessories ng 1.6V? hindi ba kasama ang visor at plate number holder/frame... Thanks.
    May 2013
    #1966
    Guys, anyone na nakapag try na ng stiff ring on their altis? Curious lang if significant nga ang effect? 😳
    Sent from my iPhone using Tapatalk - now Free
    Feb 2012
    #1967
    Sirs, may mga naging issues po ba ang 10th gen? Finally we'll be getting a medium silver 1.6g pag ok na p.o. from the bank. Kung may konting pandagdag lang pa talaga i really wanted the V variant push start, nice mags, skirts and sensors.
    Sent from my GT-I9082 using Tapatalk 2
    #1968
    Yung rattling lang sa A pillar common sa Gen 10. Mine was fixed by the casa.
    #1969
    Quote Originally Posted by rap2_tan View Post
    Mine is the annoying brake caliper "thog" sound. Greasing the caliper pin fixes it but it comes back after a few weeks; i'm asking the CASA to address this once and for all in my next service stop (replace the caliper pin under warranty?).
    Feb 2012
    #1970
    Sad to know that. What did the casa say about the issue? what year model and variant do you own sir?
    Feb 2012
    #1971
    sorry but where is that A pillar ma'am?
    #1972
    Common problem that can easily be fixed. Mine was fixed agad 2010 1.6 G Altis ko. A pillar yung pillar sa may front windshield. Mapapansin mo lang kung maselan ka sa kalampag. You wont regret an Altis. Pero sir ilang months na lang full model change na.
    Feb 2012
    #1973
    Yup lalabas na ata new gen. That's why big discounts. Instead of getting a very expensive honda civic, we chose the altis as value for money.
    Naiinis ako pag nakakakita ng V variant ang ganda kasi. Kung may pandagdag lang sana. :D
    #1974
    Quote Originally Posted by Mel Teodoro View Post
    Stiffer springs kamo? I'm willing to bet the handling should be significantly improved. The Altis suspension is tuned for comfort; i myself am tempted to go for H&R springs (1 inch drop) but i'm wary about it since i drive out of town often and the front bumper is already prone to scraping steep driveways as-is. I may go for importing Bilstein shocks from the US when the time comes to swap my shocks though.
    2012 1.6 E. The sound came out right after my 20,000km service at Toyota Shaw. They first tried the grease method but since it's coming back, we'll try to go for replacing under warranty during my next stop. The consolation is that we know where the sound is coming from (mas hassle if you still have to search for it).
    Oks lang naman yung 1.6 E or G variant. Hanap ka nalang ng aftermarket rims. In my case, i found 17" OEM Toyota rims then changed my grille to the one from the 2.0L model.
    #1975
    Here are the issues that I have experienced so far:
    1. Rattling sound on A pillar. It was immediately fixed during the 1k check-up. I think they added some pad/styrofoam to make it a little tighter.
    2. Intermittent malfunction of the trunk release cable. Fixed during 1k and 5k check-ups. Not experienced since then. Simple adjustments were made.
    3. The 'tok' sound of the front brakes. I noticed this after my 20k check-up. I just had my 25k check-up last Wednesday. Had a bolt and rubber bushing replaced. Bolt costs 40 something, rubber bushing costs 5 something, all in all its about 100 bucks for the left and right front brakes. 2 days running so far without the 'tok' sound. But the SA warned me that this sound may come back after a week or so. I'm keeping my fingers crossed.
    Other issues with no fix yet:
    1. Front bumper. As said by Vinj, it is prone to scraping. Initially, I though it just the black flaps located in front of the wheels. But to my dismay, aside from the black flaps, my bumper has lots of scratches underneath. The good thing about it is that its not that noticeable. Just be careful when going up/down on inclines, parking on slots with wheel stoppers, etc.
    2. Aircon louvers. The 2 aircon levers on the louvers (the one you use to direct the air to a certain direction), are already broken. The clips are broken thus my levers can easily fall off. The bad thing about it is that the part number is for the whole assembly which costs about 5k. I think mine was broken when the car wash boys cleaned my interior and the wiping cloth snagged into the lever. Just be extra cautious when cleaning the louvers.
    Feb 2012
    #1976
    Excited to get our brand new altis later at 3pm. Medyo nabad trip lang ako na ang available tint lang nila is black with the lumina brand. My plan kasi is to put a silver tint which i think more compliments with the medium silver color of thr car.:confused:
    but i i have no choice but to put the black tint because additional 6k daw for the black chrome tint of 3m.
    Anyway what do i have to check before receiving the car? And one question does an altis has a kilometer per liter gauge? tnx!
    #1977
    Quote Originally Posted by swankydewd View Post
    Good insights. I'll likewise try the bushing and bolt item on the brake caliper.
    *rap: congrats on the new ride. Just make sure complete yung sa checklist and malinis yung car. Pawax na rin and paint protection pag bago.
    The Altis has a km/l gauge and its where the watch is. Just press one of the buttons on the gauge panel next to the clock to get the function. You want access.
    Feb 2012
    #1978
    Tnx sir vinj. Sarap talaga ng bago! Pinabless namin agad straight from casa then Drove it to nlex already going to bulacan. Parang mas matipid pa ata ito sa vios ko. But still to observe.
    Btw, this altis pala has a newer engine dual vvti 1zr na ang engine unlike the previous model na 1zz correct me if im wrong.
    #1979
    Yes it does. Matulin pa. Iwan nga Ranger ko eh. Hanggang 175 lang kaya, yung Altis 1.6G 180 na umaangat pa.
    Apr 2013
    #1980
    Guys, saan maganda magpagawa ng wax at paint protect para sa altis dito sa south? (paranaque bf homes) TIA
    At usually mga magkano?
Toyota Corolla 10th Generation Altis Owners [continued]
