Results 3,051 to 3,060 of 3700
August 29th, 2014 11:56 AM #3051
Sir helbanes buti sayo may maingay lang namin,nanginginig pa parang tataon ung makina.may isang maganda sa avanza compare sa kuya nya yung air con system sa likod,mas malamig yung avanza kesa innova lalo na pag noontime at galit na galit si haring araw.
Posted via Tsikot Mobile App
- Aug 2014
- 4
August 29th, 2014 09:59 PM #3052ganyan dn naging problema ng 2007 Avanza G ko. pinasok ko s casa (Toyota Alabang) last Jan. 2014
August 30th, 2014 05:08 AM #3053
Anong sabi lip-cher032302? Normal ata na sa avanza yung ganon during highway speeding.
September 2nd, 2014 02:13 PM #3054
Maybe you need to have your unit checked. Elevated engine noise is normal during highspeed but not to the point it is disturbing. Sound proofing has improved in later versions. Nanginginig during highspeed is not normal.
The tires on a bad road produces more noise than that of the engine. You will notice that on good grade A asphalt.
Drive safely!
September 16th, 2014 01:35 PM #3055
Mga Sir, saan po kaya makakabili ng aircon vent ng gitnang aircon sa taas nakalagay. all the 3 vents are all destroyed and how much po kaya ito? TIA
Ask ko na din kung may FB site ba tayong mga Avanza Owners?Last edited by archangel_1911; September 16th, 2014 at 01:37 PM.
- Sep 2014
- 10
September 16th, 2014 06:07 PM #3057Gud pm po planning ko po kumuha ng avanza 1.3 E M/T ask ko lang po kong kaya po ba umakyat ng Baguio with 7 person inside. Thanks
September 17th, 2014 02:21 PM #3058
No doubt na kayang kaya ng 1.3 engine. It may be slow pero di dapat mag-alala.
Proper gearing is a must. On uphill never let your RPM get below 2000.
I would advise to get your tire pressure a bit higher than usual. Also use a higher octane gasoline upon your travel uphill.
This should help.
- Sep 2014
- 17
September 17th, 2014 05:09 PM #3059Need some help pls. My 2007 Avanza 1.5 M/T (35K odo) is giving grinding noise when you reverse (almost full turn). Wala naman when reversing straight. What could it be? Is it dangerous to drive the vehicle?
First time car owner here! TIA
- Jul 2014
- 158
September 21st, 2014 10:13 PM #3060
Xiaomi E-Car
