Page 599 of 749 FirstFirst ... 499549589595596597598599600601602603609649699 ... LastLast
Results 11,961 to 11,980 of 14970
    Oct 2007
    #11961
    Quote Originally Posted by woohoo View Post
    The only detrimental effect to the fans is the faster wear because of higher spinning speed. Parang deskfan or standfan lang iyan. Mas mabilis masira kung laging nasa highest speed setting.
    Me, I use #3 setting only after starting the engine, and before turning it off.
    HTH...
    Me, after starting the engine I switch to 1 after few seconds then 2 after about 2 secs then 3 after another 2 secs while A/C switch (the one I installed myself) is off. When I'm few blocks away to destination I switch to 3 (same procedure) while A/C switch off.
    And again I switch off A/C during uphill and hard acceleration....
    Aug 2005
    #11962
    Quote Originally Posted by yagami_kira View Post
    I noticed that the number 3 fan (front aircon) of the avanza is very loud compared to number 2.
    Will using number 3 in the long run will have detrimental effect to the fan system?
    Because sometimes in short ride, I prefer not to use aircon with window closed to avoid pollution, so I use the blower only.
    Supposed to be, dapat walang problem. iyon kasi naman aang talagang design nya. iyon lang gna kasi, maingay.
    Dec 2007
    #11963
    Quote Originally Posted by jujoe View Post
    sacrifice na talaga ako, waranty pa ako sir.
    CASA estimate cost ng alarm & powerlocks is P9k, gold rich P3400. just being practical.
    i hear you sir, kaya mejo dilema nako ngaun. discuss ko din sa wife ko kasi ayaw nya din ma void ung warranty. need to weigh in the pros and cons, para me idea talaga what exactly is to be lost by sacrificing the warranty, vs. what is to be gained by taking the practical approach
    Jun 2006
    #11964
    Quote Originally Posted by jayemkay View Post
    cguro sir ma minimize mo yung risk about sa warranty mo kung nagamit mo ng ilang bwan yung avanza mo .and also yung pagpagawan mo me iba ng nagpagawa o nagpakabit dun. dahil pag minalas ang sasabihin mo na lang cguro SANA SA CASA NA LANG. just my 2 cents.
    #11965
    Kung kaya ng budget CASA na dahil sayang ang warranty.
    Ako walang budget kaya naghanap nalang mapag kakatiwalaan na gagawa
    Dec 2007
    #11966
    Many thanks for your much valued inputs, advice and opinions, tsikoteers!
    Nov 2007
    #11967
    mga master,
    question lang po im planning na pa check up yung avanza nmin sa casa,hingi lang po ako ng advise
    *may bayad po ba papintura nung gulong sa harap yong parang "disc"
    *saka pag papalitin harap -likod ko na po yong gulong para pantay ang kas kas
    thanks po
    Sep 2005
    #11968
    Many thanks for the heads up and tips, sir puroy. mukhang sa inyo pinaka mura so far na CASA, i hope your purchase was recently. i inquired with TYT Bicutan, 7k daw. Sa TYT shaw, a whopping 10k kung walang ibang mag post na cheaper, i might just make the long trip to OTIS.
    sir boyitlog (that didn't sound quite right) thanks din po sa inputs. Sayang talaga ung sa Goldrich ni Sir Jujoe, mukhang ni-sacrifice nya talaga ung warranty, or baka tapus na ung warranty nya.
    p.s.
    to the tsikot mods, please help with my quadruple posts, pa delete nalang, sensha na.
    ummm...yung 6300 na price pala sir last march pa yun. not sure this year
    saka sir naalala ko, yung price na yan discounted kasi cash sya. original price is 7k (less 10% kasi cash). hth
    Dec 2008
    #11969
    Ok po ba ionizer for my problem or are there other solutions?
    I use avanza for delivering volume of slippers. The problem is the rugby smell from the slippers. I want to travel with ac on. So I am forced to open windows.
    Dec 2008
    #11970
    Oct 2008
    #11971
    Meron kayang fuel indicator light ang Avanza 1.3J? Kasi nung nag-park ako sa medyo slope na garahe, nakalagay na yung needle sa E. Pero hindi pa nagla-light yung fuel indicator. And is it a light or blinking?
    Sep 2005
    #11972
    yup, meron sir nasa taas ng fuel guage...dalawang instances sya.
    - 1st instance, mag-lit sya (10 liters left...i think).
    - 2nd instance, super bright yung fuel indicator (5 liters or less).
    guess ko lang yan sir.
    #11973
    hello po mga ka acp..opo mam jane ako po ung nkakita s inyo dpa po ko member nun. ngaun ok na po.hihi.
    Aug 2005
    #11974
    Quote Originally Posted by puroy View Post
    Mayroong low fuel indicator. from my estimate, mga 7 liters pa pag nag simulang umilaw.
    Observation ko lang pag nag simula ng umilaw, mahina muna then lumalakas ang ilaw hanag bumababa ang dami ng natitirang gas.
    If I remember correctly, pag naka park na mas mataas ang harap, bumababa ang pointer sa fuel indicator. pag mas mataas ang likod, tumataas naman.
    45 liters ang tank natin. Hindi ko pa nasubukan kumarga ng 40 liters pataas. 39.xx ang pinaka marami mula sa nakailaw ang low fuel indicator till sagad.
    Aug 2005
    #11975
    Quote Originally Posted by manunulat View Post
    I do not think na kaya ng ionizer na kontrahin ang amoy ng rugby.
    BTW, gumagamit nga pala ako ng ionizer imbes na air freshner.
    Sep 2005
    #11976
    subukan mo yung dehumidifier, or uling.. baka kayanin yung amoy nang goma..
    #11977
    Tanong lang uli. Mayroon na bang gumamit ng iridium spark plug sa Avanza? Mas tipid ba ang fuel consumption at puwede bang malaman by how much? Salamat.
    Nov 2007
    #11978
    mga master,"follow up po"
    *may bayad po ba papintura nung gulong sa harap yong parang "disc"(para kcng kinakalawang na un sa gulong parang disc)
    thanks po
    Aug 2005
    #11979
    Quote Originally Posted by limchrc View Post
    Mayroon dati na gumamit ng mamahalin spark plug. kaso mas maganda pa rin daw ang stock na plugs. Pa try na lang ma search ang forum.
    Aug 2005
    #11980
    Quote Originally Posted by rammed View Post
    thanks po
    Re disc sa harap, I am assuming na ang tinutukoy mo ay ang disc ng disc brakes. Yup, kinakalawang nga ang gilid nito. Possible na gamitan ng hi-temp paint. Kung ipapagawa ito, assuming puwede sa casa, may bayad malamang. pero iyong mismong surface ng disc ay hindi dapat pinturahan.
    Every 20K PMS ginagawa ang tire rotation para sabay ang pagka pudpud.
