Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Toyota Cars Talk Thread, Toyota altis 02 hard start and erratic rpm in Car Talk; Help have a toyota altis manual 02 hard starting, erratic rpm pls give list of possible parts to replace thank ...
Results 1 to 9 of 9
Thread: Toyota altis 02 hard start and erratic rpm
  1. #1
    Join Date
    Jul 2012
    Default Toyota altis 02 hard start and erratic rpm
    Help have a toyota altis manual 02 hard starting, erratic rpm pls give list of possible parts to replace thank you
  2. #2
    Nissan/Mazda Fanatic basti08's Avatar
    Join Date
    Oct 2005
    Location
    qc
    Default Re: Toyota altis 02 hard start and erratic rpm
    Have your throttle body (i think) cleaned. As always, one of the culprit in erratic idlings.
  3. #3
    Join Date
    Jul 2012
    Default
    Quote Originally Posted by basti08 View Post
    Bro done that plus tune up spark plugs changed fuel filter changed still the same
  4. #4
    Join Date
    Jun 2005
    Location
    makati
    how about the MAF sensor? have you tried cleaning it?
  5. #5
    Join Date
    Jun 2005
    Location
    makati
  6. #6
    Running on Empty...
    Join Date
    Perhaps a engine scan and compression test would help first and foremost. Then from there, have your engine checked for any signs of having sludge problems (common on the ZZ engine).
    Cleaning the MAF (Mass Air Flow) sensor can be done by doing the following:
    1. Carefully remove the MAF sensor part from the airbox housing (It's the sensor right after the air cleaner, removable with a screw driver).
    2. With some electric contact cleaner, spray generous amounts into the MAF sensor. You have to be careful not to touch the sensor hot wire and it's best to spray from a short distance and not directly.
    3. Let the sensor dry for a few minutes
    4. Re install, plug the sensor wire and start the car.
  7. #7
    Join Date
    Jul 2012
    Default
    Quote Originally Posted by sirkosero View Post
    Not yet bro i will try to do that thanks
  8. #8
    Join Date
    Jul 2012
    Default
    Okey thanks will try that.
  9. #9
    Tsikot Member b16sir_stock's Avatar
    Join Date
    Dec 2007
    almost same problem as my '02 1.6E matic... mine is happening on cold start.. almost take twice to start the engine and idling is erratic for a few minutes. but when it is warm then no problem to restart and idling is smooth.. casa replaced sparkplugs, change oil and fuel filter.. will map cleaning be the solution?
    any other problems to check?
Receive Latest Toyota Cars For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Toyota Car Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
