Results 1 to 10 of 34
- Mar 2010
- 17
February 27th, 2012 07:36 PM #1gud day! mga sir help naman po advise lang po kung ano gagawin dun sa hi commuter pag sagad na ililiko parang my umiingit sa ilalim, pero kung di naman isasagad kabig ng mamobel ok naman siya.. saka po pag 15 na ang sakay parang sumasayad na pag mejo nalubak. para po kung dalin ko sa mekaniko alam ko kung niloloko ako o hindi wala pa kasi ako kilala na mekaniko.. salamat sa in advance sa mag rereply
February 27th, 2012 08:46 PM #4
baka ibigniyan sabihin babae siya kaya wala siyang alam sa sasakyan kaya nagtatanong siya.
February 28th, 2012 09:15 AM #7
On the umiingit sound, is it consistent? Is it coming from the suspension or is it coming from the engine bay? If from engine bay and it also comes out when you're stationary and just turning the steering full lock, it may be the power steering belt or pulley.
On the kalampag when the vehicle is full, are your tire size bigger then the original tires? Is the car unusually bouncy when its running on uneven roads? If so, your shock may possibly be weak already and check your springs as well. If you have to replace the shocks, go for KYB Gas-A-Just if you usually load up the van often.
While you're at it, check and replace what's necessary with the shocks, csprings, balljoints, bushings, tie rods, control arms, etc. Para isang gawaan and gastos nalang. If that is so, do expect to spend a good amount and don't scrimp on the parts by going for cheap replacements on stuff like control arms, balljoints and bushings if they do need replacement and you plan to keep the van for a long time and use it heavily.
On the shop, try Wheelers Suspension Haus in Banawe (along N. Roxas St.) and have them take a look, or a Goodyear Servitek near your place. Then go buy the parts yourself from shops like Toyorama or NGK in Banawe.
- Mar 2010
- 17
February 28th, 2012 12:59 PM #8sorry po sa maling title, sory po kung nagkamali ako.. tama po si sir rain yun po ibig ko sabihin babae po akong walang alam sa ganitong problema..
- Mar 2010
- 17
February 28th, 2012 01:05 PM #9jut703, wala naman pong nag tatanong kung babae ka o lalake. ang tanong po kung ano problema ng hi ace commuter, ngayon po kung di mo kaya sagutin wag na po kayo mag reply.. saka po wala naman po siguro nag dududa dito kung lalake ka or babae or bading ewan ko lang sasarili mo kung duda ka. sorry po nagkamali ako ng title.
- Mar 2010
- 17
February 28th, 2012 01:12 PM #10
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
