Results 1 to 9 of 9
- Apr 2009
- 272
November 21st, 2014 11:35 AM #1Where can I buy original parts of oil seal for corolla gli 97? I found out na may leak engine leak sa car although kakapalit lang ng valve gasket and oil seals last september, I dont know what have happened. According to 2 car shops, oil seal daw nagkaproblema. Mas ok ba magpagawa sa Car shop or sa toyota mismo?They told me to buy the following parts:
Main Pulley
Camshaft oil seal
Crank shaft oil seal
How much ang cost nyan?
- Apr 2009
- 272
- Jun 2011
- 134
November 22nd, 2014 09:34 AM #3Sir,kahit san auto supply ka magtanong,basta pyesa ng toyota cgurado meron.Kung magpapalit ka ng crankshaft oil seal,isabay mo na palit ng timing belt para isang kalasan nlng.Tapos,bakit pati main pulley kailangan din palitan?
November 22nd, 2014 12:08 PM #4
include the oil pump gasket (neoprene) and the oil pump shaft seal. experience has it, that you might as well do the whole set of seals and gaskets and timing belt related parts while you're at it.
- Apr 2009
- 272
November 23rd, 2014 11:56 AM #5kasama sa mga pinalitan last september yung timing belt so no need na palitan. ilan klase ba ang oil seals meron?
November 23rd, 2014 01:37 PM #6
- Apr 2009
- 272
November 24th, 2014 02:57 AM #7
November 24th, 2014 02:19 PM #8
if you think the oil is too thick and caused the leak, the possibility it is the cause is remote. when the oil pressure gets too high, the oil pressure relief valve opens and dumps the excess volume and pressure back to the oil pan. it is the age of the car where it is time to need resealing. the next one to go if not maintained yet would be the valve cover gasket, the rear main oil seal and the oil pressure sending unit. it probably does not need to be overhauled, just resealed. try not to open a can or worms until you have the need and the convenience by having an alternate car
- Apr 2009
- 272
November 24th, 2014 04:10 PM #9Thanks for your inputs guys. I just noticed everytime i hit the gas mas marami ang drop/leak ng engine oil, if off ang car wala nman nakikitang leak, small drops lang
high idle RPM at engine start
