Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
    #21
    sir ask ko lang same na ba fuel element ng monty at fort.ngayon..??
    It's relatively easy to replace the element. Buy the part from Toyota then you can ask a mechanic to replace it for you.
    #22
    Quote Originally Posted by jalen View Post
    The Fort (at least the 2.5L) should be using a fuel element already. No idea on the Monty.
    Mar 2007
    #23
    Quote Originally Posted by millean View Post
    ok sir. any auto supply na marerecommend mo sakin sir?
    mga how much sir ung fuel filter element?
    nag papalit na ako nang fuel filter kaso andun pa din ung warning lights nang fuel sabi ni pa reset na daw ako kasi 2012 model ung innova namin salamat ano kaya dapat gawin namin at san pedeng mag pareset na mas mura mahal kasi sa kasa , maraming salamat sa mag input san pedeng mag pa reset
    Oct 2011
    #24
    how much it cost sir nun time na un?
    ah. paano ung labor? baka mas mahal ung labor :D
    labor usually nasa 300 petot sir.
    Sep 2006
    #25
    Bro ito try mo Baka pareho lang sa fortuner
    This DIY is done after replacing the fuel filter and the fuel warning light stays on.
    1. Remove the two (2) wiring harnesses on the fuel filter canister.
    2. Get in the car and insert the key to the ignition. Turn the key to IGNITION ON (don't start/crank the engine).
    3. Between 3 to 60 seconds, put back the wiring harnesses on the fuel filter canister.
    4. Observe the fuel warning light to go OFF.
    Login
    #26
    na-inis ako. pinalitan ko na lang yung buong fuel filter assembly. namatay din yung warning light... this was way back in 2006..
    next time, susubukan ko itong tip ni Langabe.
    Aug 2017
    #27
    The fuel system warning light flashes na po, pero no buzzer. And i already did the draining of fuel filter water. Pero bat ganun, amoy diesel naman po ung lumalabas hindi tubig? Kinakabahan ako fellow tsikoteers. What to do next po? Hindi ko pa po engine start kasi kinakabahan ako baka sumabog kasi amoy gas ung lumalabas. Sorry mejo magulo ung thread ko.
    Hi Guys,
    I have the same problem, recently lumabas yung warning light for fuel filter. Ask ko lang sana kung magkano aabutin pag sa casa ko dinala? Salamat sa sasagot!
    Jul 2017
    #28
    Quote Originally Posted by renzmar View Post
    Hi Guys,
    losses mo lng yung plug sa bottom of filter para lumabas kung me water then restart mo ok na.. just remember san gasoline station ka nagkarga fuel iwas ka muna dun..
    Aug 2017
    #29
    Quote Originally Posted by JMS12 View Post
    I already did na sir. Kelangan ba idrain ung filter if thats the case?
    The light stays on paps e, hindi sya nagbblink lang.
    Jul 2017
    #30
    nangyari na din yan sa isuzu dmax ko pero drain lang mechanic yung bottom ng filter tapos nawala na actually naitakbo ko pa from naia to cavite wala naman problem.. same sayo hindi nagblink talagang pirmi lang yung warning light
    Aug 2017
    #31
    Sige paps. Try ko muna idrain ung filter. Pero di mo na ba pinalitan ung fuel filter mo hanggang ngayon?
    May idea ka sir kng magkano fuel filter ng innova? Salamat
    Jul 2017
    #32
    between 350-400 pesos yun sa mga auto supply vic brand ok nmn sya
    Aug 2017
    #33
    Try ko muna dalhin sa casa pag di kaya ng budget, bili na lang sa labas. heheh
    Salamat paps!
    Aug 2017
    #34
    Salamat paps!
    #35
    Hi Guys,
    the instructions are in the owner's manual, po.
    i just followed it. it wasn't difficult, naman. just expect to dirty up your hands a bit.
    the problem was, the warning light refused to go out, even after i replaced the filter.
    perhaps if we follow langabe's tip above...
    Sep 2017
    #36
    wag po tipirin dahil napaka importante ng role ni fuel filter sa pag sala ng dumi ng panggatong sa mga tsikot natin, hmmmnn kayo rin
Need immediate help on my toyota innova D-4D Fuel Filter....
