Results 741 to 750 of 1628
June 16th, 2010 10:16 PM #741
hi! toyota owners i am new to tsikot.. I own a 08InnovaD4d my odo is 35+++... I just want to ask how much yung speed ng innova nyo on 2000rpm? In original tire size 205/65R15...because mine now is only 75kph at 2000rpm... and i notice my engine consume more fuel..and not very responsive in overtaking.I compare it when its odo 5+++. thanks for sharing.
June 16th, 2010 10:41 PM #742
At least supply pump problems are not limited to Toyota diesels. I've seen a Starex and a Ford Ranger having their supply pumps replaced, and both were under 40TKm.
Would you guys be willing to pay 20% more for cleaner diesel? Getting legislation for cleaner diesel would greatly lessen if not eliminate these issues and give us more engine choices. Maybe Toyota can finally bring in the higher powered 2.5D4d.
June 17th, 2010 12:57 AM #743
maybe it's the quality of fuel here in the PH is one the problems, i guess, why these modern diesel engines have some problems (any models).
My tip would be: Gas up at Petron, Caltex and Shell.
- Sep 2006
- 1,335
- Sep 2006
- 1,335
June 17th, 2010 08:06 AM #745
June 18th, 2010 09:51 AM #746
Sure!! If it will really result to a substantial increase in engine reliability. At that increase, it is still cheaper than gasolines.
After Ondoy, I only fuelled up at Marikina stations, specifically within our area which was hard hit, starting March of this year. Iwas noon kasi baka may tubig pa. Pero ngayon balik na uli sa suki ko.
- Mar 2009
- 3
June 18th, 2010 03:41 PM #747Hi guys! Innova owner here.. just want to share my experience with my innova.. Mine is a 2007 J Diesel Variant with 96++k mileage. Late last year na experience ko yun nag cchoke at namamatay yun makina. I went to casa last January, sabi nun service advisor papalitan nila yun Fuel Filter at i-rereset yun ECU (Toyota Q.Ave), Tinanong ko yun Service advisor kung bakit nagkakaganun and kung pwede makausap yun mekaniko para ma explain sakin kung ano talaga nangyari, sabi lang niya sakin e hindi pwede kausapin yun mekaniko, so ok lang.. umuwi na lang ako.. napansin ko hindi na resolve yun problema ng sasakyan ko.. inobserbahan ko lang muna yun sasakyan, after 1 week nawala yun pag cchoke at pagkamatay nun makina.. Anyway, Sa Shell pala ko nagkakarga, nagka problema lang yun sasakyan mula nung nakapag karga kami sa Petron Fairview.
Last Last week naman pumunta ako Tagaytay. Nagpa full Tank ako sa Shell Julia Vargas, Umulan when im on my way to Makati to pick up my friend, then suddenly while waiting dun sa sinundo ko, nag cchoke yung makina ko(First time ulit after January). Nag iikot ikot muna ko sa Makati para ma check kung mauulit.. siguro mga 5 times naulit then twice namatay yun makina.. Hinayaan ko na muna, tpos umalis na kami.. Nag Stop over kami sa Paseo Sta Rosa, we were there for about 45 minutes kaya pinatay ko muna yun makina.. Pag labas nmin sa parking namatay yun makina pag shift ko sa 3rd gear( buti walang kasunod at kasalubong kasi na stock na pati yun manibela). So I went last week sa Toyota Commonwealth(since wala na ako tiwala sa Q.Ave), sabi nun kilala kong mechanic, kelangan na daw palitan yun SCV(Suction Control Valve), lumang model na daw kasi yun innova ko and maiksi yun parang tubo dun sa SCV, kaylangan daw palitan ng bagong SCV kit.. naka schedule na ko tom for replacing the SCV kit, I’ll update you guys kung ano magiging result.. I hope maging ok na sasakyan ko.. P.S. if im not mistaken, binaha yun Shell Julia Vargas, so siguro pumili na lang tayo ng Station na hindi nabaha.
Para pala sa mga umiilaw yung Engine Light Indicator kapag umaandar yun sasakyan, EGR lang papalitan dun.. kasama yun sa Warranty kaya wala kayo babayaran. Sa Toyota Commonwealth ako nagpa gawa. i-nexplain sakin nun mekaniko na madumi lang yun sensor kaya umiilaw. After nya Mapalitan, success!! di na umiilaw yun engine light indicator, hindi na nkaka ilang mag drive. Nakaka worry kasi bka serious problem sa engine.
- Mar 2009
- 3
June 18th, 2010 03:51 PM #748
June 18th, 2010 04:20 PM #749
- Mar 2009
- 3
June 18th, 2010 07:18 PM #750
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
