Page 5 of 12 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 1627
    Jun 2006
    Bayaw ko ahente ko, meron pa din mangilan ilan na tumitirik, kahit less than a year pa. Its not the system daw, its a fuel related problem. Di lng daw sa scv ang nagiging problema minsan daw sa injectors din, which costs 20k each. Consumable daw yon.
    Feb 2010
    Quote Originally Posted by shibby75 View Post
    One time, I experience na matirikan ako, brand new pa yung fort ko on that time, I'm going to aberdeen court in Quezon City, 2.5 G M/T variant, Dual A/C on, pag-akyat ko sa parking lot, 2 times na namatayan ako ng makina even i'm on the 1st. gear, nag-ba-vibrate yung makina, then lumapit sa akin yung isang boy, nag-instruct sya sa akin na try to switch-off yung A/C, then switch-off... don lang sya naka-akyat...is it normal also with the other unit or is it the reason why the other say that 2.5 variant is under power? how you can find it out if the unit is under power?
    Apr 2010
    Share ko lang po, madalas kase ako magtravel to province and sa mga steep slopes na may break from rough road to cement, kelangan yung speed is very slow <5 km/h, parang semi-halt kase mas mataas yung semento kesa sa rough road. From first gear kaya naman, umaangat rpm niya until 2.5k to 3k rpm, nakakapag shift pa nga ako to second gear, lalo pang bibilis. so sa tingin ko ang 2.5 G ay hindi underpowered sa mga ganung instances lalo na parking ramp lang yan. By the way, the unit I drive is Hilux 4x2. Oh and by the way, yung thermostat ng aircon e nasa half, yung blower is a click higher from low.
    Feb 2010
    Quote Originally Posted by agentrambo007 View Post
    on that time, bago pa yung fort ko... then naka-on yung dual aircon...nabigla siguro sa taas ng aakyatin nya kaya tumirik... but now she's ok... kahit saan ko na sya pa-akyatin kayang-kaya na nya... she's now 2 yrs. old.
    Jun 2006
    i have driven the 2.5d4d, di naman sya underpowered. bka breakin pa makina mo. My vvti performance improved around 6000 mileage Tumitirik din ako sa usual ramp.
    0to100kph d4d wins but not so much
    race to topspeed vvti is faster which.tops/at 185.
    Feb 2010
    Thanks, I just wonder why they say that 2.5 G dsl. is under power, it's not...
    Apr 2005
    Just bought a Innova dsl AT. Well that was before I read this thread. Talaga ba na resolve na ang mga issues regarding sa D4-D engine? Some say yes, others say prevalent pa din. For my peace of mind. Kung prevalent pa din I'll have to live with it.
    Apr 2005
    To understand the problems that you and many other diesel-engine-vehicle owners encounter, we need to take a quick look at how a diesel-fuel system works.
    Like any internal-combustion engine, a diesel engine has a tank, a fuel filter, a fuel pump, and a fuel delivery and metering system. In a gasoline engine, the fuel delivery and metering system can be a carburetor or an injector. In diesel engines, it's the injection pump and injectors.
    Fuel is stored in the tank, and it travels to the injection pump and injectors after it passes through the fuel filter. What's critical in prolonging the component life of your engine is the fuel filter. Its job is to catch and prevent contaminants from getting to either the injection pump or the injectors. The contaminants include water, microscopic particles and bacteria, which may clog the fuel system over time.
    When any of the components gets clogged, you get poor engine performance because there is no longer sufficient fuel getting to the engine.
    On the other hand, when orifices inside the fuel metering system wear down, you are getting much more fuel than required. When that happens, you will see black smoke coming out of your tail pipe.
    Either way, you need to get to a diesel center to check the condition of your vehicle's injection pump.
    This is what happens during calibration: The line to every injector is checked for pressure and flow-rate capacity. They are calibrated to standard specification as required by the engine manufacturer. Anything that is out of spec is rebuilt, reconditioned, and parts are replaced when necessary.
    Unfortunately, injectors are often neglected. Why do they need to be replaced? The answer is simple. They are part of the fuel delivery and metering system, and they are subject to a much harsher operating environment compared to the injection pump. If you are not going to check them for flow rate, volume and spray pattern, and if you don't rebuild them as necessary at the same time you have your injection pump calibrated, you're wasting resources and time, particularly when there's a drivability problem with the vehicle.
    Recently, fuel companies have been coming out with diesel fuels claiming to offer better performance while being cleaner and less harmful to the environment. To my understanding, these products have been blended with additives that enhance certain properties of the fuel for the engines to run smoother and cleaner. Do note that if the mechanical aspects of the engine mentioned above aren't in proper working order, then fuel can only do so much.
    To minimize clogging and contamination I would use a very good fuel filter, choose where I get my fuel and change the fuel filter at a much shorter interval than required by the vehicle manufacturer. It's cheap insurance against a much more costly fuel system failure.
    Hope this helps!
    Regards,
    Ferman Lao
    Technical editor
    Oct 2011
    nice read sir!
    Dec 2007
    Quote Originally Posted by SEALANDER View Post
    Hope this helps!
    Regards,
    Ferman Lao
    Technical editor
    The advise on changing the fuel filter more often makes much sense. I have my fuel filter element changed everytime I have my oil change. The manual actually recommends a longer interval. Doing a fuel filter change every 5K is cheap insurance, as Mr. Lao mentioned.
    Oct 2011
    Quote Originally Posted by timo07 View Post
    Ung sa manual every how many Kilometers ang fuel filter change? pagka alam ko sa manual matagal yan.
    Jun 2008
    mas maiksi ang interval ng fuel filter change ay mas mabuti sa makina kahit anong brand or fuel ang gamit nyan. wag na antayin yang 5K km interval change, valid lang yang kung dumaan sa fuel separator/treatment unit ang fuel bago i-feed sa makina.
    Oct 2011
    btw, isa lang ba ang fuel filter sa engine? sa gasoline engine wala ng fuel filter diba?
    Dec 2007
    Sa diesel engine, hindi naka specify. Sa gasoline engine, every 80K km.
    Both Diesel and Gasoline engines of Toyota have only 1 fuel filter. fuel filters are standard in every engine. You don't want any impurities from fuel to go into your combustion chamber and wreak havoc on your cylinder liners and other components of the fuel delivery system such as injectors.
    Sep 2005
    lahat ng auto may fuel filter gas or diesel ay meron LOL.
    Apr 2005
    Top ten basic diesel engine maintenance secrets
    With the rising cost of gasoline, a lot of drivers are contemplating switching to diesel engines for fuel economy. What is the basic maintenance required for diesel engines?
    When you need an engine with steady torque and pulling power without sacrificing fuel economy, diesel engine is the preferred choice. It has a fuel efficiency of roughly 40% more than gas engines and as such, a good source of reliable power. However, the engine is massive and heavy to offset the stress of high compression which makes this engine a bit pricey compared to gasoline engines.
    When it comes to maintenance how do diesel engine compare? Shown are some important highlights below.
    1.) Unlike the gas engines, diesel engine has no electrical ignition parts like plugs, wires and moving part like distributor rotor which is subject to wear. These parts have a limited life and have to be changed on regular basis. Because of this, this is one chore we don’t have to worry about.
    2.) Diesel engines run at higher compression pressure than gasoline engines. Where the highest compression for most high performance gasoline engines is close to 200 psi, diesel runs almost 3 times that pressure. As a consequence, more heat is generated putting extra demands on the engine cooling system. Study shows diesel engines usually fail 50% more on cooling related problems because it cannot stand prolong overheating. This is why the cooling system is a high maintenance issue.
    Tips on basic diesel engine maintenance:
    Do you notice that when your gas engine overheats, you can stop it and rest the engine for a few minutes? Later you can re-start and the engine will be fine. If similar situation happens with your diesel engine, the engine is almost always damaged beyond repair.
    On some diesel engines, the cooling system uses a coolant filter to control the acidity (or ph value) of the coolant. This filter ensures that the cylinder block does not have a build up of corrosive particles inside.
    3.) Gaskets on diesel on engines must be monitored closely since they are exposed to extreme operating conditions. If possible, all mounting bolts must be re-torque at regular intervals to prevent leaks especially in the combustion mounting areas. This is also true for coolant hoses which can deteriorate quickly if not secured properly. A lot of this is also caused by engine vibrations which is common on diesel engines. Always replace a leaky gasket as a set. If one starts to leak, the rest is not far behind.
    4.) Since diesel engines use a lot of air, greater attention is paid to the engine air filtration. A common practice among truckers is to install a tell tale plastic indicator on the side of the air filter housing. The indicator changes color as soon as the engine filter element becomes dirty. Cooling this air is also critical especially if the engine is turbocharged. On some high end diesel engines they are fitted with after coolers to cool the air from turbo charger.
    5.) The oil filter selection is very important on diesel engines because of the bad elements of sulfur residue and carbon created when fuel is not burn completely. The filter used must meet or exceed the OEM filter recommended by the vehicle manufacturer. This will ensure that all corrosive particles are removed from the oil. Using synthetic oil will also help because the additives in the oil will resist premature breakdown.
    6.) Since the cooling system is critical on diesel engines, it is important that an early warning system should be in placed. Located in the dash panel, the early warning device must be easily seen and heard. If the engine has already overheated and it was not caught on time, the engine could be damaged. Most trucks have this feature in their dash and must be checked regularly to see if early warning system works.
    7.) The fuel system maintenance is handled in various ways. Always keep the fuel tank full to prevent condensation from building inside the tank which can end up in the fuel injectors. This also requires changing the fuel filters as recommended to prevent moisture build up. Some diesel engines use 2 types of fuel filters to control the presence of moisture in the engine. Some fuel tanks are also design with one way breather vents for the moisture to escape. This vent should be checked occasionally if there is a suspicion that it is restricted.
    8.) Diesel engine has very little carbon monoxide, a poisonous gas common to gasoline engines. However, it produces a lot of black soot which is the result of incomplete combustion. Most of this is caused by dirty injectors and faulty injection timing that inject too much fuel. To ward this off, glow plugs are use to heat the combustion chamber to assist in burning the fuel. These glow plugs must be checked especially before winter season.
    9.) During winter, diesel engines are normally hard to start and the best way to remedy this is to install an electrical heater to the cylinder block. Another way is to install a heater element in series with the heater hose. In extreme cases of hard starting, a starting fluid is sprayed on combustion chamber but use it sparingly to prevent scoring the cylinder walls at higher rpm.
    10.) To prevent engine cylinder block scoring, avoid prolong idle of your diesel engines. A very common habit among drivers especially in winter... diesel engines are made to idle for long hours to keep the cab warm. When diesel engines are run longer in cold temperatures, insufficient lubrication to the piston wall is the result which might lead to piston scoring. It is better off shutting it down and having it plugged in to a coolant heater which is a common practice used for gasoline vehicles in Canada.
    With the cost of fuel rising with no end in sight, diesel engine is a good alternative to gasoline engines that must be considered. Knowing the basic diesel engine maintenance is essential if you want to save money in vehicle operation and cost.
    Oct 2011
    Oct 2011
    Quote Originally Posted by Lapella View Post
    parang bitin ang article.
    Dec 2009
    Share ko lang, kanina may nakita akong Innova D4D, NOP letter ng plate no, color green, nagbubuga ng black smoke.
    Ano kaya year model nito?
    Dec 2007
    Quote Originally Posted by marz View Post
    Either 2009 or 2010 year of acquisition. Should be the facelifted version as green color came out around 2009, I think.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
