Results 1 to 6 of 6
    Apr 2009
    Im currently using 20w50 oil for my 97 toyota corolla gli. Is this ok or too much? I recently had an engine leak and im not sure if the oil has something to do with it since I just changed my oil seal and valve gasket last september
    tingin ko naman ok sya dahil malapot sya.
    yung oil leak mo eh baka hindi dun sa oil seal galing....
    OK lang yan Sir. Its actually more suitable for older cars. Just make sure you don't overfill your oil. Keep it between the max and min level (or near the max level at least but not over it). Also, do the oil level checking in the morning where all the oil has already set at the pan. Gaskets / oil seals usually wear overtime, and its normal we change them given its service lifetime
    Oct 2009
    gamit ko din yan sa 96 kong vti ok naman siya castrol brand.basta change oil lang ako every 5k
    wag mo lang palalampasin sa ikalawa butas ng deep stick mo.or baka may leak na talaga mga oil seal mo.
    Aug 2010
    Oct 2013
    Quote Originally Posted by bail View Post
    the question is where is it leaking?
Engine oil question
