Results 1 to 6 of 6
- Apr 2009
- 272
November 24th, 2014 11:23 AM #1Im currently using 20w50 oil for my 97 toyota corolla gli. Is this ok or too much? I recently had an engine leak and im not sure if the oil has something to do with it since I just changed my oil seal and valve gasket last september
November 24th, 2014 11:34 AM #2
tingin ko naman ok sya dahil malapot sya.
yung oil leak mo eh baka hindi dun sa oil seal galing....
- Nov 2008
- 641
November 24th, 2014 04:19 PM #3OK lang yan Sir. Its actually more suitable for older cars. Just make sure you don't overfill your oil. Keep it between the max and min level (or near the max level at least but not over it). Also, do the oil level checking in the morning where all the oil has already set at the pan. Gaskets / oil seals usually wear overtime, and its normal we change them given its service lifetime
- Oct 2009
- 2,271
November 25th, 2014 06:39 PM #4gamit ko din yan sa 96 kong vti ok naman siya castrol brand.basta change oil lang ako every 5k
wag mo lang palalampasin sa ikalawa butas ng deep stick mo.or baka may leak na talaga mga oil seal mo.
- Oct 2013
- 2,537
Daming issue ng SU7:grin:
Xiaomi E-Car
