Results 1 to 10 of 16
- Dec 2006
- 57
September 26th, 2014 02:21 PM #1Hi.
Any working ODB Scanner, diagnostic scan tool for Toyota Fortuner/Innova/Hilux/Hiace D4D model?
I have Bluetooth ELM327 saka Autel Maxiscan, pero cannot work sa Fortuner/Hilux/Hiace. Hindi maread ECU.
Pero both are working sa 2006 Toyota Vios and 2011 Mitsubishi Strada.
Been searching sa forums pati sa ibang bansa, mukhang mahirap nga daw maghanap ng compatible sa mga auto na to.
If may nakakaalam sa inyo or experience, please share! thanks!
- Jun 2011
- 134
September 29th, 2014 05:48 AM #2Try mo sir, pang asian market obd2 scan tool.Or check mo memoscan.cn.
- Nov 2014
- 1
November 24th, 2014 12:42 PM #3Sir mikevin.. san ka nakabili ng elm327 scanner na compatible sa 2006 vios? ang alak ko di pwede ang obd2 sa japanese made na toyota cars.. mobd ung gamit nila..
- Dec 2006
- 57
November 24th, 2014 01:04 PM #4Sir sa olx meron, mga ELM327 na color blue na bluetooth, ginamit ko sa 2006 vios to see mga KPH, sensors etc, readable naman, hindi ko pa natry sa check engine light, so tingin ko pwede, then ginamit ko din sa 2011 Strada, read and erase ng check engine light.
Pero sa Toyota D4D(innova, hiace,fortuner) hindi ko mapagana, kahit read lang ng KPH sensors etc, no response.
November 24th, 2014 03:08 PM #5
Some Toyota vehicles use Multiplex-OBD (M-OBD). The DLC may look identical to OBD-II DLCs but the pinouts and protocols used are very different.
Simply put, you'll need an M-OBD capable scantool. Needless to say, they're quite rare and can be expensive.
- Dec 2006
- 57
November 24th, 2014 03:46 PM #6
July 1st, 2015 11:34 AM #7
- Dec 2006
- 57
- Jul 2014
- 162
July 7th, 2015 11:24 AM #10
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
