Results 781 to 790 of 2046
July 31st, 2014 10:41 PM #781
- Apr 2014
- 8
August 1st, 2014 10:26 PM #783
Guys tinatry ko gamitin na lang SD card (32GB Class 4) para sa music player..pero di sya nababasa. Any ideas? Ok nmn pag USB nakasaksak.
August 1st, 2014 11:46 PM #784
The new look on the cluster is simply using the existing cluster with custom PCB board to accommodate more LEDs points. The cluster will now lights up during the day and dimmed for comfort at night. As for the seatbelt indicator a simple switch is made for the driver's side buckle and extra wiring for the ajar doors indicator as well.
- Apr 2014
- 38
August 5th, 2014 03:30 PM #785
- Apr 2014
- 6
August 5th, 2014 03:52 PM #786hello guys - need your help. I need to replace one side mirror ng Wigo ko (passenger side). As in replace, not repair. May alam ba kayo kung saan ako makakabili? For temporary use lang naman while waiting for the original part (side mirror from Toyota) to be delivered. Yun lang ang problem sa wigo, wala pang available na part sa casa.
If sa banawe, may mare-recommend ba kayo na store?
Appreciate any help, thanks!
- 52,731
August 5th, 2014 05:50 PM #787the wigo (aygo, etc..) has been in production for some time now, outside the country. your best bet is probably the katay centers in evangelista and banawe.. sorry but i don't have any definite names to give.
another possibility is, if you have kakilalas frequently going to asean countries, you might ask them to buy you one there..
last, you might try installing a curved rear view mirror over the stock rear view, to partially remedy your blindness..Last edited by dr. d; August 5th, 2014 at 05:53 PM.
- Jun 2014
- 4
August 6th, 2014 09:15 AM #789
- Jan 2007
- 354
August 8th, 2014 12:46 AM #790May I ask what the realistic Fuel consumption of a Wigo AT?
Its seems that there is a wide variations on fuel consumption.
The 3 most important aspects are:
1. Must be automatic
2. Must be very fuel efficient in the City
3. Cost of ownership is low.
Thank you.
high idle RPM at engine start
