Results 121 to 130 of 162
July 2nd, 2012 09:21 PM #122
July 2nd, 2012 09:31 PM #123
Lakas talaga. Sa 1 week na gumamit ako ng Sonata GLS, nasa 5.3 km/L lang ang FC ko. Hindi ko na-try with FC off though.
July 3rd, 2012 10:38 AM #124
It got a little more angular and closer to the Lexus ES cousin. In some angles, it does look like an Altis that bulked up on steroids. And like the '04 Altis to the model that came after it, Toyota's playing safe with not overdoing the changes to the previous Camry when designing the new one.
I like the new one. I'll probably like it some more when more of them come out.
July 7th, 2012 08:24 AM #125
The new Camry is looking better than the competition. Not so sporty as the Accord, but has a clean and well-elaborated design.
- Jun 2008
- 21
July 7th, 2012 09:20 AM #126I checked out the new Camry 2.5V at the dealer yesterday. Just a couple of observations.
1. The exterior design is sleek and elegant. The lines are simple and will not shout for attention. For those looking for a sporty ride, you have to look elsewhere.
2. The finishing details are quite disappointing. The boot looks cheap with the metal hinges or arms exposed. The insulation coverage is small and thin.
3. The interior was nothing special and the seats were covered with light tan colored leather. I personally would have preferred a darker color.
August 3rd, 2012 06:16 PM #127
Just sharing my dad's newly acquired Camry. It's a 2.5V variant in White Pearl CS color
Changed the rims and tires with a set of 19" Work Varianza D3S wheels and 245/40 R19 Nitto INVO tires to compliment the elegant/VIP look. Also added a dummy shark fin antenna and rear plate base to match the front OEM plate base. Was planning to put 20s but my dad did not want to. Masyado na daw manipis yung goma...
Here are some of the accessories that i'm planning to put on in the future:
1. Rear Ducktail Spoiler
2. Lowering Springs 1" drop
3. Daytime Running Lights
4. 4300K HIDs for fog lamps
5. Bigger muffler tip / dual exhaust
Positive and negative comments are welcomeLast edited by Juan591; August 3rd, 2012 at 06:20 PM.
August 3rd, 2012 07:14 PM #130
Seeing your cars * AEP, di na ko magugulat na talagang maganda yan camry mo *Juan...
Sakto lang yung 19s, in between siya ng looks & comfort.
high idle RPM at engine start
