Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Sep 2012
    For share lang po with regards to the Maintenance specific to Mazda 323
    I'm currently transferring the manual that I have para mas madali mag set ng schedule kaysa looking at the paper
    You may or may not agree with the items listed so choose what suits you best. On my part kasi hindi ako agree sa listed na every 10K oil change interval
    Basta may free time, I will update this thread
    To the mods, kindly transfer this to the proper category kung mali
    Thanks
    Sep 2012
    **** Every 250 Miles (400 KM) or Weekly ****
    Operations Internally and Externally
    - Visually examine the tyre for thread depth and wear or damage
    - Check and if necessary adjust tyre pressures
    Operations in the engine compartment
    - Check the engine oil level
    - Check the engine coolant level
    - Check the screen washer fluid level
    - Check the battery electrolyte level
    Sep 2012
    **** Every 6000 Miles (10,000 KM) or 6 months - whichever comes first ****
    In addition to the items listed above, carry out the following
    Operations internally and externally
    - Check the operation of all lights, indicators, instruments and windshield washer system
    - Check the operation of the cooling system
    - Check and adjust the headlight beam alignment
    - Check the operation of the handbrake
    - Check the tightness of the wheel nuts
    - Check the brake pedal height and operation
    - Check the clutch pedal height and operation
    Operations with the car raised and supported
    - Renew the engine oil
    - Renew the oil filter
    - Check the front and rear (as applicable) disc pads for wear
    - Visually examine the steering gear linkage and rubber gaiters and check the operation of the steering
    - Check the exhaust system for condition, leakage and security
    - Check the driveshafts and rubber gaiters
    - Check the valve clearances (B6 and all E series engines)
    - Check the idling speed and CO content
    - Check the condition and tension of the water pump/alternator drivebelt
    - Check the power steering fluid level and examine the fluid lines and unions for signs of leakage
    - Check the condition of the spark plugs
    - Check and adjust the contact breaker points and ignition timing (contact breaker ignition system)
    - Check the ignition timing (electronic ignition system)
    - Check the condition of the distributor cap and rotor arm
    - Check the brake fluid level
    - Check the clutch fluid level or cable adjustment (as applicable)
    - Check the manual gearbox oil level
    Sep 2012
    **** Every 12,000 Miles (20,000 KM) or 12 months - whichever comes first ****
    In addition to the operations listed under the 6,000 miles (10,000 KM) heading, carry out the following
    - Check and if necessary adjust the front and read wheel toe setting
    - Check the operation of the braking system servo unit
    - Check all chassis and body nuts and bolts for tightness
    - Visually examine the underbody, wheel arches and body panels for damage
    - Visually examine the brake pipes, hoses and unions
    - Visually examine the fuel lines for signs of leakage
    - Check the rear drum brake shoes for wear
    - Check the operation of the front and rear suspension
    - Renew the fuel filter (carburettor models)
    - Check the carburettor linkages and choke mechanism operations (carburettor models)
    - Check the operation of the throttle positioner system (B5 and all E series engined models equipped with manual gearbox)
    - Check the operation of the dashpot and throttle position switch (fuel injected models)
    - Check the automatic transmission fluid level
    - Visually examine the cooling system for leakage
    Sep 2012
    **** Every 24,000 Miles (40,000 KM) or 24 months - whichever comes first ****
    In addition to the operations listed in the 12,000 mile service, carry out the following
    - Grease the front and rear wheel bearings
    - Check the condition of the front suspension balljoints
    - Renew the manual gearbox oil
    - Drain and flush the cooling system and refill with fresh coolant
    - Renew the air filter element
    - Check the cylinder head bolts for tightness (B6 and E series engines)
    - Check the inlet and exhaust manifold nuts and bolts for tightness
    - Renew the fuel filter (fuel injected models)
    - Renew the brake fluid
    **** Every 60,000 Miles (100,000 KM) ****
    - Renew the timing belt (B series engines)
    Sep 2012
    Double check your engine type on this one kasi madami klase B3 engine series na 1.3
    Engine and cooling system 323, 1.3 1989 to 1991
    Type B3. SOHC 16V
    Capacity (cm3) / number of cylinders 1324 / 4
    Compression ratio / pressure bar 9.4 / ³9.5
    Oil pressure bar [3.0 to 4.0]
    Oil temperature ºC _
    Valve clearance - inlet mm 0.30 H
    Valve clearance - exhaust mm 0.30 H
    Firing order 1-3-4-2
    No 1 cylinder position TBE
    Thermostat opening temperature ºC 80.5 to 83.5
    Radiator cap pressure bar 0.76 to 1.04
    Fuel system 323, 1.3 1989 to 1991
    Idle speed - manual [auto] rpm 850 to 900
    Fast idle speed - manual [auto] rpm 1250 to 1750
    CO * idle speed [3000 rpm] % ²0.3
    HC * idle speed [3000 rpm] ppm ²200
    CO2 * idle speed [3000 rpm] % _
    Carburettor / fuel injection Aisan
    Type / ref 28-32 2V Downdraught
    Main jet / needle 97, 162
    Injection pressure bar _
    Pump pressure bar 0.28 to 0.35
    Octane rating RON 91[E 91 RON]
    Ignition system 323, 1.3 1989 to 1991
    Type Electronic
    Ignition coil _
    Primary resistance ohms 0.77 to 0.95
    Ballast resistor ohms _
    Voltage - Tmnl 15(+) to earth V _
    Distributor _
    Points gap (air gap) mm _
    Dwell angle º (%) _
    Condenser capacity μF _
    Rotation _
    Ignition timing - basic [static º Crankshaft * rpm 0±1 BTDC * idle
    V = Vacuum NV = No Vacuum NV
    Total ignition advance º Crankshaft * rpm _
    Centrifugal check.
    º Crankshaft * rpm
    0 * 1200
    º Crankshaft * rpm 12 to 16 * 2700
    º Crankshaft * rpm 16 to 20 * 3600
    Vacuum range check mbar 133 to 454
    Maximum vacuum advance º Crankshaft 12 to 16
    Spark plugs NGK/Champion
    Type BKR5E, 6E / RC9YC
    Electrode gap mm 0.70 to 0.80
    Sep 2012
    Break muna dito for today sa ibang araw na yung iba
    Sep 2008
    I have a 1992 Mazda 323 1.8L A/T nandito ako sa Australia. Bp5 engine JM0BG10P ang VIN
    Sep 2012
    Quote Originally Posted by bmacavanza View Post
    I'll check this tonight if I have a reference for your engine type. But the first parts stated in the scheduled preventive maintenance still applies to you
    Sep 2012
    Fault Diagnosis / Troubleshooting Guide
    1) Engine
    Engine fails to rotate when attempting to start
    * Battery terminal connections loose or corroded
    * Battery discharged or faulty
    * Broken, loose or disconnected wiring in the starting circuit
    * Defective starter solenoid or switch
    * Defective starter motor
    * Starter pinion or flywheel ring gear teeth loose or broken
    * Engine earth strap broken or disconnected
    Engine rotates but will not start
    * Fuel tank empty
    * Battery discharged (engine rotates slowly)
    * Ignition components damped or damaged
    * Broken, loose or disconnected wiring in the ignition circuit
    * Worn, faulty or incorrectly gapped spark plugs
    * Choke mechanism sticking, incorrectly adjusted, or faulty - carburettor models
    * Dirty or incorrectly gapped contact breaker points - pre 1982 models
    * Faulty condenser - pre 1982 models
    * Major mechanical failure leg camshaft drive
    Engine difficult to start when cold
    * Other ignition system fault
    * Low cylinder compression
    Engine difficult to start when hot
    * Air filter element dirty or clogged
    * Carburettor float chamber flooding
    Sep 2012
    Starter motor noisy or excessively rough in engagement
    * Starter motor mounting bolts loose or missing
    * Starter motor internal components worn or damaged
    Engine starts but stops immediately
    * Insufficient fuel reaching the fuel system
    * Loose or faulty electrical connections in the ignition circuit
    * Vacuum leak at the carburettor/throttle housing or inlet manifold
    * Blocked carburettor jet(s) or internal passages
    * Fuel injection system faulty
    Engine idles erratically
    * Incorrectly adjusted idle speed and/or mixture settings
    * Air filter element clogged
    * Vacuum leak at the carburettor, inlet manifold or associated hoses - carburettor models
    * Vacuum leak at the throttle housing, surge tank, inlet manifold or associated hoses - fuel injected models
    * Incorrectly adjusted valve clearances - B6 and E Series engines
    * Faulty HLA Adjuster(s) - B3 and B5 engines
    * Uneven or low cylinder compressions
    * Camshaft lobes worn
    * Timing belt/chain incorrectly tensioned
    Engine misfires at idle speed
    * Faulty spark plug HT leads
    * Incorrectly adjusted idle mixture settings
    * Incorrect ignition timing
    * Distributor cap cracked or tracking internally
    * Disconnected, leaking or perished crankcase ventilation hoses
    Sep 2012
    Engine misfires throughout the driving speed range
    * Carburettor worn or incorrectly adjusted
    * Fuel filter choked
    * Fuel pump faulty or delivery pressure low
    * Fuel tank vent blocked or fuel pipes restricted
    Engine hesitates on acceleration
    * Carburettor accelerator pump faulty
    Engine stalls
    * Throttle positioner/idle-up system (where fitted) incorrectly adjusted
    Sep 2012
    Engine lacks power
    * Timing belt/chain incorrectly fitted or tensioned
    * Brakes binding
    * Clutch slipping
    * Automatic transmission fluid level incorrect
    Engine backfires
    * Ignition timing incorrect
    Oil pressure warning light illuminated with engine running
    * Low oil level or incorrect grade
    * Faulty oil pressure transmitter (sender) unit
    * Worn engine bearings and/or oil pump
    * High engine operating temperature
    * Oil pressure relief valve defective
    * Oil pick-up strainer clogged
    Engine runs-on after switching off
    * Idle speed excessively high
    * Faulty fuel cut off solenoid - carburettor models
    * Excessive carbon build-up in engine
    Engine Noises
    Pre-ignition (pinking) or knocking during acceleration or under load
    * Incorrect grade of fuel
    * Worn or damaged distributor or other ignition system component
    Whistling or wheezing noises
    * Leaking inlet manifold or carburettor gasket - carburettor models
    * Leaking inlet manifold or throttle housing/surge tank gasket - fuel injected models
    * Leaking exhaust manifold gasket or pipe to manifold joint
    * Leaking vacuum hose
    * Blowing cylinder head gasket
    Tapping or rattling noises
    * Incorrect valve clearances - B6 and E Series engines
    * Worn valve gear or camshaft
    * Worn timing chain or tensioner - E Series engines
    * Ancillary component fault (water pump, alternator, etc.)
    Knocking or thumping noises
    * Worn big end bearings (regular heavy knockings, perhaps less under load)
    * Worn main bearings (rumbling and knocking, perhaps worsening under load)
    * Piston slap (most noticeable when cold)
    Sep 2012
    2) Cooling System
    Overheating
    * Insufficient coolant in the system
    * Thermostat faulty
    * Radiator core blocked or grille restricted
    * Electric cooling fan or thermoswitch faulty
    * Pressure cap faulty
    * Water pump drivebelt worn, or incorrectly adjusted
    * Inaccurate temperature gauge sender unit
    * Air lock in cooling system
    Overcooling
    * Thermostat faulty
    External coolant leakage
    * Deteriorated or damaged hoses or hose clips
    * Radiator core or heater matrix leaking
    * Water pump seal leaking
    * Boiling due to overheating
    * Core plug leaking
    Internal coolant leakage
    * Leaking cylinder head gasket
    * Cracked cylinder head or cylinder bore
    Corrosion
    * Infrequent draining or flushing
    * Incorrect antifreeze mixture or incorrect type
    Sep 2012
    3) Fuel and exhaust system
    Excessive fuel consumption
    * Choke mechanism incorrectly adjusted or choke sticking - carburettor models
    * Tyres underinflated
    Fuel leakage and/or fuel odour
    * Damaged or corroded fuel tank, pipes or connections
    Excessive noise or fumes from exhaust system
    * Leaking exhaust system
    * Leaking, corroded, or damaged silencers or pipe
    * Broken mountings causing body or suspension contact
    Sep 2012
    4) Clutch
    Pedal travels to floor - no pressure or very little resistance
    * Broken clutch cable - cable operated clutch
    * Low hydraulic fluid level - hydraulically operated clutch
    * Incorrect clutch cable adjustment
    * Air in the hydraulic system
    * Broken clutch release bearing or fork
    * Broken diaphragm spring in clutch pressure plate
    Clutch fails to disengage (unable to select gears)
    * Incorrect clutch pedal adjustment
    * Clutch disk sticking on gearbox input shaft splines
    * Clutch disc sticking on flywheel or pressure plate
    * Faulty pressure plate assembly
    * Gearbox input shaft seized in crankshaft spigot bearing
    * Clutch release mechanism worn or incorrectly assembled
    Clutch slips (engine speed increases with no increase in vehicle speed)
    * Hydraulic fluid level too high
    * Clutch disc linings excessively worn
    * Clutch disc linings contaminated with oil or grease
    * Faulty pressure plate or weak diaphragm spring
    Judder as clutch is engaged
    * Clutch disc cable sticking or frayed
    * Clutch master or opening cylinder piston sticking
    * Faulty or distorted pressure plate or diaphragm spring
    * Worn or loose gearbox mountings
    * Clutch disc hub or gearbox input splines worn
    Noise when depressing or releasing clutch pedal
    * Worn clutch release bearing
    * Worn or dry clutch pedal bushes
    * Pressure plate diaphragm spring broken
    * Broken clutch disc cushioning springs
    Sep 2012
    5) Manual Gearbox
    Noisy in neutral when engine running
    * Input shaft bearings worn (noise apparent when clutch pedal released but not when depressed)
    * Clutch release bearing worn (noise apparent when clutch pedal depressed less when released)
    Noisy in one particular gear
    * Worn, damaged or chipped gear teeth
    Difficulty engaging gears
    * Clutch fault
    * Worn or damaged gear linkage
    * Incorrectly adjusted gear linkage
    * Worn synchronizer units
    Jumps out of gear
    * Worn selector forks
    Vibration
    * Lack of oil
    * Worn bearings
    Lubricant leaks
    * Leaking differential output oil seal
    * Leaking housing joint
    * Leaking input shift oil seal
    Sep 2012
    6) Automatic transmission
    Note
    Due to the complexity of the automatic transmission, it is difficult for the home mechanic to properly diagnose and service this unit. For problems other than the following, the vehicle should be taken to a dealer service department or automatic transmission specialist.
    Fluid leakage
    * Automatic transmission fluid is usually deep red in colour. Fluid leaks should not be confused with engine oil which can easily be blown onto the transmission by air flow.
    * To determine the source of a leak, first remove all the built up dirt and grime from transmission housing and surrounding areas using a degreasing agent or by steam cleaning. Drive the vehicle at a low speed so air flow will not blow the leak from its source. Raise and support the vehicle and determine where the leak is coming from. The following are common areas of leakage
    (a) Oil Pan
    (b) Dipstick tube
    (c) Transmission to oil cooler pipes/unions
    Transmission blown or has burned smell
    * Transmission fluid low or needs renewal
    General gear selection problems
    * The following are common problems which may be caused by poorly adjusted linkage:
    (a) Engine starting in gears other than Park or Neutral
    (b) Indicator on gear selector level pointing to a gear other than the one actually being used
    (c) Vehicle moves when in Park or Neutral
    (d) Poor gear shift quality or erratic gear changes
    Transmission will not downshift (kickdown) with accelerator pedal fully depressed
    * Low transmission fluid level
    * Incorrect selector mechanism adjustment
    * Incorrect kickdown switch adjustment
    Engine will not start in any gear, or starts in gears other than Park or Neutral
    * Incorrect starter/inhibitor switch adjustment
    Transmission slips, shifts roughly, is noisy or has no drive in forward or reverse gears
    * There are many problem causes for the above problems, but the home mechanic should be concerned with one possibility - fluid level. Before taking the vehicle to a dealer or transmission specialist, check the fluid level and condition of the fluid. Correct the fluid level as necessary or change the fluid and filter if needed. If the problem persists, professional help will be necessary.
    Sep 2012
    7) Driveshafts
    Clicking and knocking noise on turns (at slow speed on full lock)
    * Lack of velocity joint lubricant
    * Worn outer constant velocity joint
    Vibration when accelerating or decelerating
    * Worn inner constant velocity joint
    * Bent or distorted driveshaft
    Sep 2012
    8) Braking system
    Note
    Before assuming that a brake problem exists, make sure that the tyres are in good condition and correctly inflated, the front wheel alignment is correct and the vehicle is not loaded with weight in an unequal manner
    Vehicle pulls to one side under braking
    * Worn, defective, damaged, or contaminated front or rear brake pads/shoes on one side
    * Seized or partly seized front or rear brake caliper/wheel cylinder piston
    * A mixture of brake pad/shoe lining materials fitted between sides
    * Brake caliper mounting bolts loose
    * Worn or damage steering or suspension components
    * Faulty dual proportioning valve
    Noise (grinding or high pitched squeal) when brakes applied
    * Brake pad or shoe friction lining material worn down to metal backing
    * Excessive corrosion of brake disk or drum (May be apparent after the vehicle has been standing for some time)
    * Foreign object (stone chipping etc.) trapped between brake disc and splash shield
    Excessive brake pedal travel
    * Inappropriate rear brake self-adjust mechanism
    * Faulty master cylinder
    * Air in hydraulic system
    * Faulty vacuum servo unit
    Brake pedal feels spongy when depressed
    * Deteriorated flexible rubber brake hoses
    * Master cylinder mounting nuts loose
    Excessive brake pedal effort required to stop vehicle
    * Disconnected, damaged or insecure brake servo vacuum hose
    * Primary or secondary hydraulic circuit failure
    * Seized brake caliper or wheel cylinder pistons
    * Brake pads or brake shoes incorrectly fitted
    * Incorrect grade of brake pads or brake shoes fitted
    * Brake pads or brake shoe linings contaminated
    Judder felt through brake pedal or steering wheel when braking
    * Excessive run-out or distortion of front discs or rear drum/discs
    * Brake pad or brake shoe linings worn
    * Brake caliper or rear brake backplate mounting bolts loose
    * Wear in suspension or steering components or mountings
    Brakes binding
    * Incorrectly adjusted hand brake mechanism or linkage
    Rear wheels locking under normal braking
    * Rear brake shoe lining contaminated
Mazda 323 Troubleshooting Guide and Maintenance Reference
