Page 52 of 134 FirstFirst ... 24248495051525354555662102 ... LastLast
Results 1,021 to 1,040 of 2668
    Apr 2010
    #1021
    Quote Originally Posted by annot View Post
    tnx *olidotcom kahit sa gasoline man lang sana naglagay sila hehehe
    hay nako sir.. same thoughts... same thoughts... pero ok lang.. we cant have everything...
    May 2008
    #1022
    my apv with 25pcs cpu and 20pcs 19inch samsung.. break in period hehehe
    #1023
    Di ba nahirapan yung APV mo. Bigtime ka pala sir annot
    #1024
    Pwde bang malaman, sino sino dito ang nagpachange oil after 1K at kung sa CASA kayo nagpachange oil?
    Apr 2010
    #1025
    Quote Originally Posted by snowballs View Post
    nope.. not me.
    May 2008
    #1026
    small time lang sir hehe.. naiakyat naman sa 6th floor rufino tower yung delivery ko..
    o.t. and shameless plug lol.. im annot din of tipidpc.com and pinoydvd.com baka need nyo HDs and HD media player...
    Aug 2004
    #1027
    hi APV owners!
    Looking at the new APV a/t SGX at the moment, bka meron kayo dealer na alam na mejo maganda ang offer. Basic lang ang kailangan ko. Nakausap ko na ang Suzuki diosdado makapagal at marilao(sm) branches..
    Diosdado macapagal branch
    Php 810,000
    downpayment Php 188k+
    monthly amor Php 15k+
    Marilao(sm branch)
    Php 810,000
    downpayment Php 155k+
    monthly amor Php 16+
    siguro kung may freebies na maganda rin sana like back up sensors, rain visors, leather seat covers and so on...
    Thanks all!
    Apr 2010
    #1028
    Quote Originally Posted by spidey1211 View Post
    hi APV owners!
    Php 810,000
    Marilao(sm branch)
    Php 810,000
    Thanks all!
    SGX sir is top of the line na. i believe that it includes the rain visors, 2din headunit and backing camera. not sure about the sensor...
    #1029
    Quote Originally Posted by olidotcom View Post
    wow may backup camera na? cool. wala ba talagang 8-seater na SGX A/T?
    May 2008
    #1030
    sa commonwealth suzuki alam ko bibitawan na nila suzuki products and meron pa sila 2 stock of SGX sabi sakin pag yun daw kunin ko less 30k discount..
    Apr 2010
    #1031
    Quote Originally Posted by coiter View Post
    afaik sir wala 'ata'... ginawa nilang captains chair yung sa 2nd row kaya ganun. parang style starex.. pang celebrity. hehehe...
    #1032
    share ko lang experience ko sa Suzuki Alabang regarding battery water. Nag pa PM ako nung december,2010. tapos nitong january,2011 ay nag-hard starting na yung APV ko. when i checked the battery, i can see the plates. meaning low level ang tubig.
    Matutuyo po ba in one month time ang tubig ng battery considering na PM siya last december?
    Tiningnan ko din po yung PM checklist eh kasama ang checking ng battery. Nag inform kami sa suzuki service at babalikan daw kami. It has been a week now at di pa rin kami binabalikan.
    Ingat kayo, double check n'yo din after PM like oil level, ATF level, brake fluid level, battery water, at yung iba pang kaya natin ma-check. Mahirap na baka tumirik na lang ang sasakyan natin.
    Apr 2010
    #1033
    Quote Originally Posted by daycode88 View Post
    hi sir, this is correct. it has been an issue regarding battery water being dried up fast. since our battery is not the free-maintenance type. tapos nasa tabi din ng engine which is a heat source, the battery water tends to evaporate fast.
    it is always advisable to check battery water every month... come to think of it.. its time to check mine as well.. hehehe...
    #1034
    Kanina habang papaark ako, may narinig akong malakas na tunog galing sa loob ng APV. Di ko alam kung yung handbreak iyon pero chineck ko yung handbreak ko para syang lumawag although nung tinest ko naman kumapit naman yung handbreak pero parang lumuwag pag tinataas.
    Bumaba kasi ako ng APV para buksan yung gate at magpark. Nung bumalik na ako sa sasakyan at paandarin ng 6 to 10 feet duon ko narinig yung malakas na tunog (na parang may bumigay). Di ko kasi maalala kung nilift ko yng handbreak kaya yung agad ang pumasok sa isip ko at yung tunog parang galing sa malapit hand break.
    Apr 2010
    #1035
    best sir is to check the break line.. baka naputol sir yung isang line going to 1 wheel... im not sure but alam ko dalawa siya diba? 1 on each wheel..
    #1036
    paano ba iyon icheck sir olidotcom, di ko alam? by the way nung tinest ko naman yung hand break may narinig naman akong 4-5clicks nung tinaas ko yung handbreak
    Apr 2010
    #1037
    hi sir, the clicks are coming from a plate inside your handbrake housing. so that's normal to be heard.
    Im assuming since you said na "gumaang" yung pag hatak ng handbrake, but still you feel that its working, im assuming that one of the lines are cut. or maybe natanggal lang...
    but since I havent seen the complete handbrake assembly, im just assuming that its a typical assembly where from the handbrake, 2 cables are going out to the back of the APV into the wheels separately.
    best is check under the back wheels. look for a cable na parang sa bisikleta, where it will travel from the back wheels going to the area where your handbrake is located. it should be 2... one for each rear wheel. try to pull the cable for stiffness.. pero dahan dahan lang.. baka kasi ibang cable yun.. make sure its a cable.. not a hose.. hehehe.. baka brake hose na siya.. or gas hose. wahehehhee...
    Apr 2010
    #1038
    eto sir, grabbed a picture of an underside of our APV. i have circled in red yung handbrake cables nya. hopefully you can check it on your APV as well.
    Oct 2008
    #1039
    *boss oli.. APV ko yan ah? hehehe..
    Apr 2010
    #1040
    Quote Originally Posted by totie_phoyah View Post
    hehee.. sorry sir. pero pinutol ko yung mga "SUPER SECRET" parts mo.. para hindi alam kung ano laman..
Suzuki APV [Merged Threads]
