Page 130 of 134 FirstFirst ... 3080120126127128129130131132133134 LastLast
Results 2,581 to 2,600 of 2668
    Jan 2019
    #2581
    Quote Originally Posted by chronicle View Post
    It needs to be thoroughly checked.
    Remove the filler plug and check the oil.
    Even if all and engine sound is ok?
    Apr 2014
    #2582
    Quote Originally Posted by typelogic View Post
    Differential is part of the transmission.
    Rear wheel drive ang sasakyan mo diba?
    Jan 2019
    #2583
    Yes rear wheel drive manual transmission. The kasa is just doing visuals and asking q
    Apr 2014
    #2584
    Tell them to check the oil. Hindi silip silip lang na parang may ginagawa.
    Jan 2019
    #2585
    I tried YouTube to fix my Suzuki APV front bumper dent but boiling water cannot pop out the dent. Any tips?
    IMG2197267271 — imgbb.com
    Oct 2014
    #2586
    Fiber glass boys can fixed this easily. [emoji106]
    Sent from my SM-A600G using Tapatalk
    #2587
    IMG2�19�726�7271� — imgbb.com
    i saw some banawe boys fix one such, but not an APV.
    they used a heavy-duty hair dryer.
    Apr 2014
    #2588
    Remove the black cladding on the wheel well. Then while the bumper is hot, push it from the inside.
    Jan 2019
    #2589
    Yes, that seems to be what is needed to be done. I thought, boiling water alone and not removing the bumper can fixed it. The ABS plastic bumper needs some pushing from the inside because it has a certain degree of hardness in it, and in tandem with a heater element. Therefore, the bumper needs to be removed first.
    #2590
    is there something behind the bumper, that prevents you from pushing it outward from behind?
    if you can't get your hand or fist in, use a long but thin object, like a length of 2 x 2.
    turn the wheel to the right to create more space.
    Jan 2019
    #2591
    APV is 7 months. How much will insurance shoulder? I checked suzuki casa and I was surprised they eeager to replace even if the bumper dent looks fixable with heater. Brand new bumper excluding labor is P17T. I read the insurance papers 3 pages but it is written in Esperanto - hard to get. I was in a hurry and didn't stayed long. Any tips? Can insurance shoulder the new bumper replacement? Staff also said I need to notarized the bumper dent with an attorney.
    Apr 2014
    #2592
    You will still need to pay participation fee.
    So if there is no hole on it, ill prolly just go with the diy method first. Will save a few thousand bucks.
    #2593
    most insurance contracts have a participation fee of about 2 or 3 thousand bucks, plus hassle documents and loooong downtime for the vehicle.
    the banawe boys can probably do it for a few hundred bucks, in less than 30 minutes, without bringing the bumper down.
    how long na po?
    mine kasi, a sentra, had one the size of a softball. it healed itself in about 2 weeks. one day it was there, two weeks later, it was back to normal. "self-healing bumpers."
    Jan 2019
    #2594
    how long na po?
    It happened last July 25, 2019. No holes coz the contact object is rounded
    #2595
    wait a couple of weeks, po.
    your bumper looks like it's made from the same material as my self-healed bumper.
    Jan 2019
    #2596
    It got fixed by Cebu's car dent/paint specialist shop for P1500.
    IMG219728111233 — imgbb.com
    #2597
    good for you, sir.
    kinailangan bang ibaba yung bumper?
    Jan 2019
    #2598
    good for you, sir.
    For my case no need. He removed 2 plastic clips so his hand can push from the inside. In tandem with a heating device, one push popped it out. A few more heating to even the surface and wipe with water. After the fix, it looked like original. No scratches, no dents and all plastic clip/screw intact
    Jan 2019
    #2599
    I open the front bonnet hood of my Suzuki APV, intending to pour distilled water for the radiator. I need to make sure where to pour it. Need help. Also how often should I do this routine? I drive daily with aircon. Where I see dripping water which is normal. I'm not seeing dripping water this time, hence I think I need to pour in distilled water into the radiator correct?
    Apr 2014
    #2600
    A/c dripping is just a byproduct of the system (freon, etc)
    The coolant or distilled water on the radiator has nothing to do with it.
    Unless you are experiencing an overheat wherein you have very low on coolant level, then you should put at the very least distilled on the resovoir located near the radiator.
Suzuki APV [Merged Threads]
