Results 1,281 to 1,290 of 2666
- Oct 2012
- 93
October 23rd, 2012 08:54 AM #1281I was a the showroom at Suzuki, E. Rodriguez in Q.C. last week and saw a GA model with double
aircon at 605,000.00 Php. It has a Philair sticker at the rear glass window but my 2006 model AT
apv is a Denso according to the service center here in Manila. I check in my second hand apv
yesterday because the compressor stopped running and they said that it was empty of freon.
The cost is 12,900.00 Php that includes expansion valves for front and rear, dryer, labor and etc.
Separate cost for parts like evaporator, condenser or compressor. They called me up yesterday
afternoon and said that even though the compressor is a Denso brand they don't have the shaft
seal in stock for my car's compressor model. They need to send the compressor to their other
branch today if it can be repaired and if not, the new one cost 22,000.00 Php. If it can be repaired,
the cost is estimated at 7,000.00 Php plus. I hope it can be repaired !
- Sep 2003
- 74
October 23rd, 2012 10:39 PM #1282It was only last Sunday that I noticed, affected din pala Type 2 ko. In my APV's case, yung front driver's side tire lang ang affected. May mga part sa inner side ng rubber na wala na yung grooves (upod na). Yung other front tire mukhang normal pa naman. What I'm planning to do is replace na lang muna the affected tire with the reserve tire kung pareho lang ito and .... ano pa po kaya pwedeng gawin?
- Oct 2012
- 93
October 24th, 2012 08:51 AM #1284Just an update, yesterday the Denso service center called me up and said that my apv compressor can be fixed by
their other branch and will be shipped back to them today for installation. According to them, there are no other
parts that needs repair and my total cost now is 18,400.00 Php. 12,900.00 Php for aircon general servicing plus
5,500.00 Php for compressor repair.
- Oct 2012
- 93
October 24th, 2012 10:28 PM #1286Yes sir, it was much better. Picked up my second hand apv this afternoon at Crown Common Rail Diesel Center which
is also an authorized Denso service center. Got aircon cooling back again! Before I took the car out, I noticed some
stains in the outside but mostly in the inside, especially on the beige color leather seat covers. I complained but all they
can say is sorry sir. They are good in servicing aircon but not that good in keeping your car clean as it was when I check
it in! Nothing was missing in the car but when I opened to see the engine, the power steering fluid was almost empty
and I had to go out to buy two 12 oz. bottle to refill it. I think, they were running the car on idle to observe the cooling
capacity of the aircon but since the rack and pinion was leaking, it drained out almost all the fluids. I also noticed the
water coolant reservoir was at low level when it should be at full.
I will be taking the apv tomorrow to Suzuki to have the rack and pinion replace and the cost just keep coming!
- Oct 2012
- 93
October 25th, 2012 07:24 PM #1288
This is how it looks when the power steering fluid is leaking out of the bellows(boots) connecting the
tie rod end and rack & pinion assembly. The car is already at Suzuki (CASA) and might release
it to me this Saturday. According to them it will take about one day to replace the rack and pinion
assembly. They still have to align the front wheels and check for other problems. I ask them how
much will be the labor cost and said, they charge 600.00 Php per hour for doing a specific job. So
if it takes about seven hours, the cost will be 4,200.00 Php already.
- Jan 2011
- 40
October 26th, 2012 04:22 AM #1289update on my 2nd hand apv too....
change stabilizer link on both sides.p380/each
change brake pads (bosch brand) p650/set
change air cleaner (federal mogul brand) p400
total labor 520.
October 26th, 2012 05:42 AM #1290
suking mekaniko sir?
regarding brake pads.. front and rear? (brake shoe)?
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
