Napapalitan ko na ng fuse, meron pala reserve fuse duon sa takip, thanks.
Just come across the thread where some tsikoteers used Baldwin oil filters. Can i use this on the APV, maybe couple with sythethic oil for 10k intervals perhaps?
Guys any idea sa fluctuating engine temps? Bumababa ung temperature ng APV minsan.
mga sirs, malapit na mag 35k yung apv ko, and mag diy change oil ako using helix hx7, last change oil ko was 31k. sabay ko na rin ng airfilters and spark plugs.
however, yung last casa ng previous owner at 28k nagpalit ng ATF. i read dito sa thread before na may papalitan pa na part sa A/T during 30k pms and hindi naman nagawa yun nung 28k pms. planning to have the A/T pms done at casa pero yun lang.
ATF pump ba yung need palitan? am trying to backread pero hindi ko mahanap sa haba ng thread. how much din if ever.
thanks!
thanks!
Mga sir yung apv ko ayaw magstart. Check ko na kuryente ok, yung dustribution ng gas ok din. Spark plug check. Ano kaya sira nito?
Kindly double check all connections. Baka battery poles. If still ayaw talaga mag start why not call a mechanic na lang sir.
Paano mo nakita ok ang kuryente? Check mo din ignition coils at crank sensor. Sana hindi ecu ang sira o putol na timing belt.
