Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    Apr 2011
    #21
    update: nawala yun grinding sound after ko palitan ng hardware kit. sana maganda ang result. obserbahan ko parin. thanks sa mga input guys.
    Apr 2011
    #22
    as usual bumalik nanaman yun brake noise. oh well. hopeless na talaga auto ko
    Feb 2009
    #23
    Quote Originally Posted by sn0wbLind View Post
    follow the recommendations in the previous posts! your car was made by man, it can be repaired, remade, modified or altered by man. nothing is impossible to fix when it comes to cars to put her back in the road
    Aug 2009
    #24
    having the same predicament with my 7g galant. almost all in the previous threads were done but to no avail. maximum tolerance to date, hayyyz.
    Apr 2011
    #25
    nag research ako sa net.. since may ABS yun sentra ko..pwede din daw panggalingan ng sound yun.. pero pano ko malalaman na sa abs ang culprit?
    *9701
    ganyan din ba problem mo?
    Feb 2009
    #26
    *9701
    in the process of possibility elimination that the ABS is causing your symptoms, disable the abs by removing the abs fuse. the brakes revert back to foundation hydraulic brakes with vacuum assist.
    Apr 2011
    #27
    Still no lock with that abs fuse trick
    Feb 2009
    #28
    you described two noises. is it both screeching and grinding? using common household noises, use a good known similar noise for comparison. check beyond the brakes if you have tried most of the common brake repair procedure. it might be worn out suspension bushings or wheel bearing that is making noise. do a visual inspection if there are metal shavings around the suspected noise area. check for tightness of the fasteners that may have been disturbed. insufficiently torqued fasteners make that noise. the mating surfaces between the rotor and the hub must be free of debris. the mating surfaces between the caliper bracket and the steering knuckle must also be free of debris and torqued to specs
    Apr 2011
    #29
    sir parang crunching metal sound and tunog nya
    Feb 2009
    #30
    have you checked the wheel bearings and the brakes splash shield?
    Apr 2011
    #31
    splash shield already checked.. wheel bearings not yet. tingin niyo sir pwedeng eto ang dahilan? how? hindi ko din kasi ma imagine. how about cv joint?
    Aug 2009
    #32
    *9701
    Yep, even went to the extent of replacing my front bearings and having OEM brake pads lately. mine has a sound of parang pinuputol naman na kahoy or as if ung sound ng hydraulic na upuan kapag luma na. though with my other rig, using bendix, maingay talaga as in heavy metal sound pag start ko ng driving sa umaga but pag nakalayo na ako ng mga 1km or more, ala na sound, normal na.
    Apr 2011
    #33
    hindi gumana yun pag palit ng wheel bearing? yun pa naman plan ko.
    Aug 2009
    #34
    bro, in my case yun ha. just sharing my own experience po yun. after magpalit ng mga bearing i voluntarily "pulled down" the whole suspension system as well just to make sure of its condition but there again, 0 findings. sabi nga ng mrs ko, baka daw naghahanap na ng bagong may-ari, hehehe.
    Apr 2011
    #35
    guys, mukhang nakita ko na talaga yun culprit.
    WHEEL HUB sabi ng wheelers. hanap ako surplus then sabay ko na din wheel bearing.. feeling ko eto na talaga kasi pinakita sakin oblong na pag na sspin. nilagyan pansamantala ng grasa sa wheel hub. nawala yun ingay.
    Aug 2009
    #36
    snowblind: makibalita ako ng aftermath mo sir ha.... good luck.
    Apr 2011
    #37
    yep! nagtanong na ako ng mga piyesa sa nisparts...yun wheel hub sa surplus lang daw makakahanap. meron lang sila wheel bearing.
    Apr 2011
    #38
    dahil dito sa quote na to, naniwala ako na maayos auto ko! salamat!
    Dec 2019
    #39
    ano nangyari sa problem mo bro? naayos din ba?
    halos ganyan din kasi problema ko. kaya lang ang sa akin kapag tumtakbo ka ng over 60kph tapos nagpreno ka, nagkakaroon ng rattling and shaking sound na nagmumula sa kaliwang unahan. Pinalitan na outer CV joint (umiingit na rin kasi) pati engine supports, pati strut mount, kaso meron pa ring "shuddering" o "rattling" sound. ramdam mo sa brakes at pat sa auto body. Pinagpalit namin ang rotor disc - dahil kung yung kaliwang rotor disc and may sabit, lilipat yung rattle sa kanan. Kaso talagang sa kaliwa pa rin nagsisimula kapag nag-brake ka.
    Nung una, ang iniisip naming culprit yung rack bushing (EPS ang steering ko) kasi umuuga kapag inuga mo yung rack. Kaso wala kang mahanap ng ganyang bushing, kaya ginawan ng remedyo ng mekaniko. Humigpit naman, pero hindi pa rin nawala yung ratlling noise kapag nagpreno ka sa 60kph up. Brand new ang feel ng suspension at steering ngayon, yun nga lang may kalampag.
    Hope anyone can help.
    Quote Originally Posted by Falconkrest View Post
    Hows the caliper pins? Or guide...
screeching/grinding sound when braking
