Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 93
    Oct 2011
    Internal TPMS looks much safer to me.
    Jun 2015
    Hi,
    For those still looking for a reliable TPMS, we are carrying the Steelmate TP-71I TPMS with Internal sensors and cig plug visual display. It retails for 8,990 and installation costs around more or less 800 near banawe =)
    For more information, you can check out ND AutoMart - Car Parts & Accessories, Electronics Store | Facebook
    Hi,
    For more information, you can check out www.facebook.com/ndautomart
    Jun 2013
    Am I too late for this?
    Jun 2016
    Quote Originally Posted by jedi View Post
    I will install this new Wireless TPMS to my car, before offering it to the public. There are internal and external sensors but i chose to get the external TPMS for DIY purposes. Internal sensors will also be available.
    Let me guide you on why TPMS is very important
    Protection in advance:TPMS directly monitors the Tire's pressure and temperature.when the tire show an abnormal sign,TPMS can Promptly notice the driver to do some corresponding measure to avoid accidents and ensure safety.
    Extend the tire’s life:when tire’s pressure is 10% pressure value under standard,the tire’s lifespan will reduce 15%.with in-time digital display of pressure and temperature value,TPMS can help driver to keep tire the standard pressure,so as to extend the tire’s life.
    Save Fuel consumption:when the tire’s pressure is 30% below standard,the fuel consumption increase 15%.TPMS can help drive to keep the tire’s standard pressure,cut fuel consumption.
    Protect automobile parts:if driving when the tire is not at the standard pressure(too high or too low),it will bring some abrasion to the engine chassis and suspended system.
    Guarantee the normally-operating Brake System:if the tire’s pressure is not in balance,it will make the vehicle run deviate in braking,so as to increase the accident risk.
    Monitor the tire in real time:TPMS can help driver control the tire condition easily at any moment in vehicle,so as to help drive to make right decision,and ensure safety.
    External TPMS
    Internal TPMS
    1.TPMS (Wireless-External sensors):
    a. Display
    b. cigar lighter charger
    c. external mounted sensor
    d. anti-thief nozzle
    2. Functions and Features
    Product Features
    (1) Real time monitoring tire pressure and temperature at the same time.
    (2) Display show pressure and temperature of 4 tires on screen.
    (3) Display show which tire is abnormal.
    (4) Powerful function include low pressure alarm, high pressure alarm, leakage alarm, high temperature alarm, low sensor battery alarm, low display battery alarm, signal missing alarm.
    (5) Alarm with beep sound and display screen red light flashing.
    (6) Sensor battery changeable.
    (7) Dual power supply of battery and charger.
    Alarm Function
    (1) Leakage alarm: The pressure decrease over 0.2Bar in 20 seconds
    (2) Low pressure alarm: The pressure is lower than standard about 25%
    (3) High Pressure Alarm: The pressure is higher than standard about 40%
    (4) High temperature alarm: The temperature of tire is over the threshold
    (5) Low power of sensor alarm: The power of any sensor is less than 2.4v
    (6) No signal alarm: Missing some sensors’ message over 25 minutes after it start to work
    Operating Functions
    (1) Pressure Unit setting: change Bar to PSI (pre-set unit is bar)
    (2) Temperature Unit setting : change °C to °F (pre-set unit is °C)
    (3) Standard pressure setting: increase or decrease (pre-set value is cold tire pressure 2.4 Bar)
    (4) High temperature alarm threshold setting: pre-set threshold is 80°C
    (5) Set up sensor: learn new sensor ID code when replace sensor
    (6) Exchange tires position: when mismatch sensor to tires, change position on display
    call me at 09053338777 , 09228335588, 3481728.. I am willing to give special price for the first few orders.
    There will be two models to choose from... Wireless External and Wireless Internal
    SRP: P11,000
    Advance Order: P9,000 for wireless or external TPMS
    sir hindi ko na po makita yung picture??
    May 2009
    may mga P3k plus lang na steelmate, carchet and other brands sa amazon....DIY versions.
    positive naman ang mga reviews kahit yung hindi mga steelmate.
  6. #6
    up for this thread. i've seen some sellers in lazada as well. parang 9K with installation yung pinapasok talaga sa tires. tapos there's a bluetooth one.
  7. #7
    Is it safe to use this? It won't damage the wheels?
    Jul 2014
    Quote Originally Posted by April_Ryan View Post
    Hi sir. Ano po nainstall mo?planning to buy one also..
    Sent from my XT1650 using Tapatalk
    Aug 2005
    Anybody using the Spy brand tpms?
    Sent from my SM-C900F using Tapatalk
    Oct 2017
    Hi i am planning to replace the tpms tire air with nitro. Any recommendation where is the best service place for this ? Yun marunong na talyer...thanks
    Sent from my SM-G950F using Tsikot Forums mobile app
    Jan 2020
    External TPMS
    Internal TPMS
    a. Display
    Product Features
    Alarm Function
    Operating Functions
    SRP: P11,000
    This is important to have in the car
    Feb 2012
    SRP: P11,000
    Imagine, from 9,000 to almost 800.00 na lang. Salamat Shopee (at Lazada) talaga.
    Looking to try one set since madalas na bumababa ang tire pressure ng iba kong gulong.
    My only worry is wala kayang epekto sa tire balance ito? Or magaan lang siya?
    Sep 2016
    Quote Originally Posted by gearhead000 View Post
    Magaan lang sya. Ang gamit ko is yung external tapos USB yung bluetooth receiver. Sa android HU ko minomonitor yung tire pressure.
    Jul 2013
    gaano katagal battery life nya? and replaceable ba yung battery?
    Sep 2016
    May 2021 ko nabili yung akin. So far okay pa naman. CR1632 yung battery nya. May tool na kasama pangbukas ng sensor para mapalitan ang battery.
    Dati mahirap maghanap ng batt ng mga yan pero nowadays madami na sa mga hardware stores like ace, true value, & handyman.
    Btw, iyong mga solar powered tpms monitors niyo maganda pa ang charging? Iyong akin kung matagal naka shade medyo naghihingalo na. Pero pag naarawan ok nanaman [emoji16]
    Jan 2009
    In my case, there's tint between it and the glass so solar charging is not efficient. What I do is charge it using USB every couple of months or so pag nakita ko 1-2 bars nalang. Yung solar charging still works to some extent kasi it extends the battery capacity so madalang ko lang i-charge using USB.
    Jul 2013
    More than 2 years ko nang pinag-iisipan itong TPMS na ito.
    Mawawala na itong forum, di pa din ako decided.
    Pero most likely lalagyan ko mga motor namin... then if all goes well, isusunod ko na yung cars.
    Sep 2004
    Very useful etong tpms. Ma monitor mo in real time pressure ng gulong. Re battery life ng mga sensor ung sa FR sensor nung
    sa akin mga 3 months lang inaabot then the rest mga 5 to 6 months naman
    Sep 2016
    Kuha ka na sir. Ako rin hesitant nung una kung need ko ba talaga yun or hindi. Ngayon, pagstart pa lang ng kotse kita ko na kung need ko ba magpahangin muna or okay pa gulong ko.
Wireless  TPMS Tire Pressure Monitoring System
