Results 1 to 10 of 12
- Aug 2014
- 391
October 16th, 2014 08:39 AM #1Hi tsikoters,
when should i replace the shock absorbers? what would be the symptoms, assuming that there is no leaking on its hydraulics.
thanks in advance.
October 16th, 2014 10:38 AM #2
you need to replace your shocks when:
a. it takes a longer distance for you to stop.
b. when you hit the brake, the vehicle nose-dives (in case of front shocks)
c. you may notice some vibrations on your steering wheel (in case of front shocks)
d. car veers or slides when braking
e. the car rocks, or in other words, matagtag in uneven roads, bumps
f. you observe uneven tire wear (although this is also related to incorrect camber)
how to check?
a. physical check.... meron bang leaks or wet spots sa stem ng shocks?
b. Push down hard on each corner of a vehicle. If the car continues to bounce after you let go, sira na ang shocks.
October 16th, 2014 12:35 PM #3
ganuon pala yaon, kaya pala sabi nung taga jiga ng mag palit ako tagas na sir ang fluid at sisirain din nya iba parts ng sasakyan nyo kaya dapat palitan nga. kaya ng mapalitan na ayos na pati mga bushing at link napaltan nadin kase pati mga yaon naapektuhan ng sirang shock.
- Aug 2014
- 391
October 16th, 2014 12:43 PM #4Salamat..
below are true: on my car.
b. Push down hard on each corner of a vehicle. If the car continues to bounce after you let go, sira na ang shocks. ---- same yata to kung merong sasakay or kung aalugin mo yung car, ang daling maalug.
Thanks 1D4LV
- Oct 2014
- 11
October 16th, 2014 05:30 PM #5most of the time dampeners lang kailangan i replace unless damay na rin yung springs and it's rusted out.
November 8th, 2014 03:18 PM #6
OT
nasa magkano (labor only) ang damage for shock replacement?
any mechanic can do it?
ok ba sa zafra motors?
November 8th, 2014 07:44 PM #7
- Jul 2013
- 2,450
November 8th, 2014 09:14 PM #8
- 52,731
November 9th, 2014 12:03 AM #9
- Dec 2016
- 27
October 3rd, 2017 10:41 PM #10Nasa magkano ang shocks ng sasakyan?subcompact sedan for example. Matagtag na din yung takbo ng akin pag lubak, nagpachange oil ako neto and napansin ko kinakalawang na na yung shock sa likod yung isa is nagpapawis(sinabi sa kin nung mechanic na leak nga yun pero hindi gaano), i dunno if effect din ng paliting shocks na yung pag lubak and medyo matulin, sobra kalabugan ng gulong?
high idle RPM at engine start
