is it mandatory to perform wheel alignment after a change of shock absorbers?
Printable View
yes. after changing springs, chances are your alignment, camber or caster may be out of spec. its well worth it since you will be preventing premature/unnecessaary wear and tear on your tires.
thnks userfriendly, thought so. Then if that is the case should i be charged for it (alignment) separately by the same workshop that performed the shocks changeout?
It will be charged separately
thanks hitman531ph for the input..
^Depends on the rear suspension of your car. Some cars today have a fixed solid beam/axle set-up so alignment and camber is unnecessary for the rear tires. However,if your rear suspension is adjustable then it is required to have it aligned nonetheless.
Has anyone tried availing of the services of Tire Center? I saw one of their branch in Manila Abad Santos. Okay ba ang service dito?
