Results 1 to 7 of 7
October 1st, 2014 01:47 PM #1
Mga sir napansin ko tank ng steering nag bawas ng fluid nasa middle nalang ng max at min dahil pala nag leak. At napansin ko rin pag nag da drive ako yung manubela may play sa right side at yung sa left side naman medyo matigas at kahit kunting ikot ko lang parang may medyo talbog, halimbawa pag nag drive ako sa highway yung steering sa right side may play parang maluwag pero sa left side naman medyo matigas parang may naka tukod at parang matalbog kahit kunting ikot lang sa manubela. Napa ayos ko naman yung mga ball joint ko last july. Baka nakaranas kayo ng ganito ano kaya problem nito? Isuzu trooper surplas pala to sir.
- Aug 2012
- 2,767
October 1st, 2014 05:10 PM #2Uneven or rough steering
- Improperly adjusted rack guide > Adjust rack guide. If the problem is not corrected, replace the gear box.
- Belt slipping on pulley > Adjust the belt tension. Replace the belt if necessary.
- Air in reservoir or check power steering fluid level > Add fluid to the specified level. Check for leaks in the system.
Fix mo agad ang source ng leak. Do not let it get worse.
- Aug 2012
- 2,767
October 1st, 2014 06:40 PM #5it looks like the top of the valve housing is leaking. replace the valve oil seal.
October 2nd, 2014 06:46 PM #6
Sir pina check ko ito sa shop then siningil ako ng 5,000 sa labor i think na mahal yung singil nila. Ano sa tingin nyo sir mahal ba sa 5k ang labor?
- Aug 2012
- 2,767
October 2nd, 2014 10:17 PM #7hindi ako familiar sa pricing ng labor ngayon. i suggest magpa-quote ka pa sa ibang shops para ma-compare mo.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
