Results 1 to 10 of 21
March 22nd, 2007 10:16 AM #1
guys saang shop kayo nagpupunta to have your brake pads changed? i've been looking over the forums and the net and mukhang kaya naman i-diy. kaya lang ang problem ko wala akong gamit especially when it's time to push back the brake piston.
also, nakikita ko marami suggestion is to use bendix standard. mga how much ito and meron ba nito sa blade/true value/concorde or do i have to go to banawe pa?
many thanks.
March 22nd, 2007 03:44 PM #2
Most auto decently stocked auto supplies should have bendix pads available for the more popular car models. You can have your suking talyer or gas station do the pad change and perhaps you may want to drain/change your brake fluid as well and clean the rear drums.
In Banawe, you can try Wheelers Suspension Haus.
March 22nd, 2007 04:29 PM #3
sa suking auto supply merong bendix or kung merong bosch mas okay.
pakabit mo na lang sa suking brake specialist or mechanic.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 22nd, 2007 08:11 PM #4that's a simple job. if you're in the area feel free to pass by the shop
March 23rd, 2007 12:58 AM #5
sa shell dati nagpakabit ako 250 lang labor on both sides. ako bumili ng pads
March 26th, 2007 04:46 PM #6
di ba kailangan pa i-reface and rotor disc nyan so that the new break pad will sit properly?
March 26th, 2007 05:41 PM #7
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 4th, 2007 10:10 PM #10Ang brake pads ba ay depende sa car model? Magkano kaya rear pads for Chevy Venture?
Thank you!
