Results 171 to 180 of 296
November 27th, 2011 11:31 PM #171
Gas shocks are more intended pag ang auto mo is gamit pang buhatan on the rear part of your car. But if you use your car on a daily basis and minimal lng din yung load na dala-dala mo, you will really notice that ang tigas ng bagsak ng ride mo pag naka gas type ka
. Thats why hangang ngayon eh still OEM released ang mga fluid type shocks sa mga newer cars dahil that one is still tested to give you a more smoother ride. JIL store in banawe corner e.rodriguez sells KYB shocks for AUV's at around 600pesos and KYB gas type at around 1,200 yta, double the price of the fluid type then just have it installed to one of your favorite gas stations.
- Nov 2011
- 12
December 20th, 2011 07:13 PM #172sirs, need suggestion on front shock replacement, compliance bushing and wheel alignment for civic 2002 Vti-S.
nag canvass ako sa honda, magkaiba presyo binigay for left and right dahil sa ABS.
any suggestions sa shop sa banawe area (diagnosis+parts+labor)?
suggestions sa alternative sa OEM parts welcome din. thanks.
- Dec 2011
- 6
January 1st, 2012 10:12 AM #173mga sir ask ko lang if pano mo malalaman kung palitin na yung shocks, sorry bago lng sa tsikot world..
medyo bumagsak kase sa left sideyung oto ko.. takot lang ako bka lumalala.. TIA
January 2nd, 2012 12:15 PM #174
Wheelers Suspension Haus in Banawe used to do the suspension work on my old 2001 ES body Civic. They can also source the parts for you and you can cross-canvass with shops such as Multiline (?).
If you do a bounce test or while you're driving, the car bounces more uncontrollably when it hits dips. If you do a visual test, there's fluid leaking out. Best to have your mechanic check it also as it may also be the spring and not the shocks.
- Dec 2011
- 6
January 3rd, 2012 06:32 AM #175thanks sa advice sir.. pmunta kase ako sa cruven yday kaya lng sarado pala sila...
nka tanabe lowering springs kase ako... chineck ko nman wala nman leak..
as far as sa ride wala nman akong nararamdaman na bounce maybe kase nka lowered?
thanks!
- Jan 2012
- 3
January 18th, 2012 01:25 PM #176does anybody knows where i can buy original toyota spare parts such as brake pads, shock absorbers, window motor, door locks and many others whose prices are not same as that of toyota parts dealer... my immediate need is front shock absorbers for toyota vios 2006. would you know what brand of shox toyota uses for vios 2006? pls help me find stores... thank you..
- Jan 2012
- 3
January 18th, 2012 01:42 PM #177does anybody know where i can buy original toyota spare parts such as brake pads, shock absorbers, window motor, door locks and many others whose prices are not same as that of toyota parts dealer... my immediate need is front shock absorbers for toyota vios 2006. would you know what brand of shox toyota uses for vios 2006? pls help me find stores... thank you..
January 18th, 2012 02:47 PM #178
- Jan 2012
- 3
January 18th, 2012 03:12 PM #179thank you so much po sir, i will call them asap. kyb brand po ba ay same as kayaba brand na kine carry ng SERVICTEK? thank you po again.
The current gen Kicks e-power is basically a compromise, as the body+chassis design came first...
2025 Nissan Kicks
