Results 1 to 11 of 11
    Oct 2009
    guys, ano kaya problema ng oto ko. 17rim, lower. malambot naman yung steering wheel when driving normaly pero when i take turns or when im stopped and then taking turns ang tigas sobra. hirap tuloy mag parking. wala naman leak power steering also, tama naman yung level ng fluid. normal ba to? tnx.
    Apr 2010
    Baka restricted ang flow ng power steering fluid kung minsan na mamaga ang loob ng hose kung luma na lumiliit ang butas. May nangyari pa sa akin isang beses nagpagawa ako ng hose ang ipinalit yon pala mallit ang butas ng hose kaya matigas manibela at malakas ang vibration ng hose.
    Oct 2009
    Quote Originally Posted by Vootlog View Post
    eh sir, oem pa din yung power steering di pa din napapalitan... anyway thanks. ill sa ps specialist.
    Your hoses or pump might be blocked. Have them checked. How old is your car? I just changed all the hoses in the power steering system of my SUV and the hoses were all brittle causing a vibration with the wheel when I turned it while the car is stationary.
    Jan 2009
    Not really the topic at hand but I just want to say that turning the steering wheel while the car is stationary puts a lot of stress on the steering linkages. It is best to turn the wheel while the car is in motion (even very slowly).
    Oct 2011
    pero pag mga tight parallel parking, you need to fully turn the steering wheel with the vehicle stationary.
    Jul 2006
    Correct, lalo na if the tyres are wide.
    Jan 2008
    lalo na kung naka tapak ka pa sa brakes.. lalong matigas yan...
Power steering problem? matigas steering on turns.
