Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 58
    Sep 2014
    #41
    One more thing po, I've noticed na mabula yung fluid inside the reservoir. Parang softdrinks.
    Aug 2012
    #42
    Air bubbles in the reservoir
    - Check for crushed inlet hose or a loose hose clamp allowing air into the suction side of the system.
    - Check for cracks in reservoir
    Pump
    - Front seal leaking > Replace front seal
    - Pump housing leaks at either end > Replace the housing O-rings. If the housing still leaks, replace the pump.
    Pump outlet hose (High-pressure)
    - Leaking at the threaded fitting > Tighten the fitting. If it's still leaking, replace the O-ring or pump outlet hose.
    - Leaking at the swaged point > Replace the pump outlet hose
    Pump inlet hose (Low-pressure)
    - Leaking because of damage, deterioration of improper assembly > Replace or repair as necessary
    Jan 2014
    #43
    ako din napnsin ko din na parang may bula din tapos sa semento yung patak nya ganun din may parang bula din lalo na pag medyo elevated pababa ang parada dami tagas pag flat surface di naman ganun kadami patak
    Sep 2014
    #44
    *red_one
    Thanks for the help. I called Mang Toto and he said it's the PS pump that needs to be replaced. Another whooping 9,000 for the surplus lang. Anyone knows where to get a cheaper part? Also, is mang Toto really that reliable? :-(
    Posted via Tsikot Mobile App
    Sep 2014
    #45
    If I may add, sabi nung mechanic in our area, pump na nga daw talaga kasi puro gasgas na daw. Ganun ba talaga yun? Pag gasgas need palitan?
    Aug 2012
    #46
    Quote Originally Posted by ecstaticx View Post
    like any other parts, need lang palitan if faulty na or not repairable. alin ba yung may gasgas -- external or internal component ng pump?
    Aug 2012
    #47
    Quote Originally Posted by Red Advent 04 View Post
    fix mo agad ang source ng leak. don't let it get worse.
    Jun 2014
    #48
    Pano nya nalaman na gasgas? Pinabaklas mo ba yung pump?
    I could be wrong pero baka nga pump talaga problem ng crv mo may way para ma test yung pump mo kaso kakalasin yan eh.ikot ka sa banawe baka makahanp ka ng mas mura pa pero make sure na yan Talaga sira baka kc kaya pa irepair yna kung oring lng mga sira.
    Mar 2011
    #49
    Na experience ko dati na pag nag add ka different brand na PS fluid or atf, mag bubbles sya.
    Sep 2006
    #50
    *red_one
    Try niyo magtanong Kay Engine Master marami silang surplus na ganyan.
Power Steering Problem
