Results 11 to 20 of 22
- Oct 2009
- 2,271
July 31st, 2014 02:23 PM #11try mo dito sa evangelista bangkal makati.
kapag binaklas yan pa check mo nadin ung mga parts na may tama kasi kalasin ang pina rotor nyan,para isang gawaan nalang
August 1st, 2014 09:11 AM #12
- 52,701
August 1st, 2014 10:49 AM #13totoopo.
kung walang clearance ay mag-babanggaan yang mga gears at hindi na i-ikot..
kapag sumobra naman, ay lalagutok parang worn ball joint..
August 1st, 2014 11:52 AM #14
August 1st, 2014 12:34 PM #15
August 2nd, 2014 10:12 AM #16
- 52,701
August 2nd, 2014 02:57 PM #17
August 3rd, 2014 09:41 AM #18
August 4th, 2014 10:16 AM #19
Ganyan din dati kong sentra yung 1st to 2nd may shift shock. I suggest palitan mo na atf, pero kapag yung drain and refill and process mo you still have around 3 liters pa na matitira sa loob ng torque converter. Para malinis ng todo yung loob you may perform several atf change, at least everytime you change your engine's oil or yung dialysis method ng pagpalit ng atf na gawin mo.
If after several atf change at ganun pa rin it may be the governor of the transmission. Yun ang nagko-control ng pressure ng langis sa loob ng transmission. Pero you need not worry dahil di ka naman ititirik niyan kailangan mahanap mo lang ang tamang release ng silinyador kapag mararamdaman mo na mag chechange shift ka na from 1st to 2nd. Mas nakakatakot yung transmission na kahit na anong gas mo mabagal arangkada. Your current scenario will still last you at least 5 years kung di ka naman mapagparusa sa saksakyan.Last edited by Bin Diesel; August 4th, 2014 at 10:18 AM.
August 22nd, 2014 06:01 PM #20
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
