Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Suspension, Steering and Brakes Talk Thread, Naninikit na brakes in The Workshop; Hello tsikoteers, just wanna have some accurate advices po sana. More than a week ago, tumirik po ang car ko ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree1Likes
Thread: Naninikit na brakes
  1. #1
    Join Date
    Apr 2010
    Location
    Cavite
    Default Naninikit na brakes
    Hello tsikoteers, just wanna have some accurate advices po sana. More than a week ago, tumirik po ang car ko and I smell something na nasusunog na goma. I checked all the tires only to find out that my 2 front mags are hot kaya pala ayaw umandar dahil sa paninikit ng brakes, so I called a nearby mechanic and told me that my caliper brakes need to overhaul.
    To make the long story short, dinala po namin yung car sa shop nila at kinalas mga caliper brakes, niliha at konting linis ang ginawa then they charged me for 600 labor.
    So after a day, maayos sa umpisa ang brakes pero pag matagal ng ginagamit ay tumitigas po ang brake pedal at mejo nangangamoy uli ang preno. Binalik ko uli sa kanila at nilinisan lang uli un mga brakes at sabi ay okey na daw. But just recently ay nangyari na naman po ang same scenario...Im sick and tired of this na pabalik balik po ako sa shop at abala sa oras. I just want to have enlightenment kung ano po kaya ang sira ng car. Sabi nung chief mechanic ay baka daw busted na yung piston pero sabi naman po nung gumagawa ay maayos daw yung piston at linis lang ang kelangan...kaso ay paulit ulit na lang pong nangyayari eh. Very reliable po ang car ko kahit pa may kalumaan na at nagagamit ko kahit saang long drives..pero lately hinde po ako panatag sa auto, kahit mag-grocery lang ako, 2 blocks away from ours ay nangangamba akong manikit na naman ang preno (which again happened yesterday).
    Ano po kaya ang real culprit at permanent solution about my brake problem? Gusto ko po kasi masolusyonan ito ng tama at hinde ko naman po madala sa ibang shop dahil sayang naman po binayaran kong labor sa kanila na hinde pa naman nila totally naayos.
    By the way, my ride is nissan 86
    Sorry po if medyo mahaba ang queries ko. TIA )
  2. #2
    Join Date
    Jan 2008
    Location
    Las Pinas
    Default Re: Naninikit na brakes
    its a clear case of a busted hydro-vacuum assist.. replace your hydro-vac asap
  3. #3
    Join Date
    Apr 2010
    Location
    Cavite
    Sir yapoy, hydrovac po ba ang problem kahit na yung brake at mags sa front right side lang ang umiinit at madalas umiipit ang preno? Actually, both front brakes and mags ang umiinit, but only the right side is drastically hotter, hinde po mahahawakan in bear hands dahil siguradong mapapaso...while the front left side ay halos maligamgam lang naman
  4. #4
    Join Date
    Jan 2008
    Location
    Las Pinas
    malamang sa malamang hydrovac ang problem kasi sabi ok naman ang caliper mo
  5. #5
    Tsikot Member Rank 2 t2erns's Avatar
    Join Date
    Location
    bulacan
    the brake booster or hydrovac (tawag ng iba) is there only para mag assist sa tapak sa pedal (thus it's called brake booster). one side of that big cylinder is vac and the other side is atmospheric pressure. so walang kinalaman sa pag stuck up ng brake (pwera na lang kung masyado mahaba ang pushrod at nakatulak agad sa master cylinder (not common).
    from your kwento parang nililinis lang nila at hindi pinapalitan ng caliper overhauling kit kaya pabalik balik ang paninikit ng preno. since medyo me edad na yung car maaring sira na rin ang internal ng brake hose kung baga steel braided ito meron na mga himulmol yun sa loob at hindi na nakakabalik ang fluid pag bitaw sa pedal.
  6. #6
    Join Date
    Apr 2010
    Location
    Cavite
    Quote Originally Posted by t2erns View Post
    Sir t2erns, in my understanding from what you have said...pagbalik ko po sa shop I should suggest the followings:
    - palitan ang piston ng caliper (I think, ito ata yung rubber thing na pinakita sa akin ng mechanic)
    - check / clean the brake hose
    Hinde din po kasi nababanggit ng chief mechanic na hydrovac ang problem, but I really appreciate sir yapoy's inputs (Im open in everyone's help naman po).
    And logically speaking po, if hydrovac is the culprit, the 4 wheels will have the same problems, am I correct? But in my case, only the front mags and brakes are having issues...specifically, the front right side na laging umiipit ng husto ang preno.
    TIA po mga gurus
  7. #7
    Join Date
    Location
    bulacan
    not specifically the piston, but yung kit na rubber na parang flat o-ring and the dust boot (parang accordion). and be sure na not grease ang gagamitin but either brake fluid or petroleum jelly. i'm not familiar with your car's brake but baka me posilibilidad nagkabaligtad ng kabit ang left sa right, the bleeder screw must be on top.
  8. #8
    Tsikot Member Rank 2 gearhead000's Avatar
    Join Date
    Feb 2012
    Location
    Marikina City
    have you tried bleeding your brake fluid especially sa harap?
  9. #9
    Join Date
    IMO, likely yung caliper pistons may deep scratches/rusting na sya. Even if they try to clean out the rust with sandpaper kung malalim ang scratches your pistons will stick (won't return to its original position) once it gets hot. To test if your hydrovac/brake booster works, step on your brakes while the engine is off. Start the engine and if the pedal sinks slightly, your hydrovac should be okay (this means that the vacuum created by your engine is able to activate the hydrovac). If it doesn't sink, your hydrovac is likely defective or the vacuum hose has a leak or the valve inside the vacuum hose is sticking. I am assuming that hindi ginalaw yung adjustment ng pushrod ng hydrovac. By the way, if you change the pistons, you should also replace the rubber boots (aka caliper kit). The boots keep the dust away from the brake system/fluid and prevents the fluid from leaking out.
  10. #10
    Tsikot Member Rank 4
    Join Date
    Feb 2009
    Location
    here, there & everywhere
    from the write ups, my hunch is you have a nissan sentra. the system is a diagonal split brake system. the right front is paired with the left rear and the left front is paired with the right rear. your brake hoses are probably collapsed from age or improper service procedures. have both front brake hoses replaced. in the process, have the master cylinder overhauled or replaced. the compensating port in the mc might be plugged.
Receive Latest Cars For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
