have passed through that situation din..
hmmm... una talaga baka makatipid pero in a week time.. naglowering springsdin akohehe
posted by Autoxer sa HCP
Cutting stock springs to lower car.
Cost of cutting at sidewalk "talyer" 800 + 150/spring cutting charge.
Cost to replace blown shocks due to cut stock springs. ~1800x4 = 7200 + 800 labor =8000.
Add that to the 1400 you spent to cut your springs = 9600.
Add 750x4(cost of replacement springs)= 3000.
That would be 12600.
That doesn't include the gas & time you waste to get the parts you had to replace.
In perspective, a set of H&R sport springs used to cost 10500.
Help naman
Hey guys
Meron bang lowering springs at leaf sa likod pangmaliliit na auto kagaya ng auto ko na suzuki fronte? Ano brand?
plus: an option to go back to stock again and sell your lowering springs or vice versa... walang sayang.Originally posted by Supierreman
In perspective, a set of H&R sport springs used to cost 10500.![]()
guys, tanong lang po. if i buy lowering springs, then i should get gas shocks instead of fluid? bakit po? thanks.
gearspeed,
Hindi ba binabasan lang ng leaves ang spring or gumagamit ng lowering block?
Grail.
It is primarily for better handling and to avoid 'bottoming out' the suspension when you hit bumps.
pansin ko lang..most modern cars (even my 97 familia) gas shocks na..does this mean hindi na kelangan palitan?
sorry po at ot na
..errr...basta, wag tipirin ang pag lower kasi mas magastos. period.
ako rin nag pa cut ng springs dati... dahil mahirap pa mag hanap ng lowering springs dati pang corolla. Soobrang tagtag... as in tumatalbog ako habang umaandar.. hassle. Lowered yung car for a yr, and ang bumigay lang naman (fortunately) is the bump stops ng shocks.
Nagpalowered na kase ako.Ang ginawa nila sa likod nilagyan lang nila ng tatlong lowering block. Sa unahan ko cut springs lang 2 putol dahil marami pa naman yung ikot ng springs ko...Matagtag nga lang kapag hindi maganda yung road..Pero balak ko na maglagay ng lowering springs sa unahan na kahit hindi maganda ang road hindi siya matagtag...gearspeed
Kung merong kayo maadvise na pagmaliit na kotse na lowering springs at shocks..Sabihin niyo naman kung ano brand?...Thanks...
bros, ok ba gumamit ng lower spring? ano ba pede lowering spring para sa corolla 93? sa harap l ang kse gusto ko i-lower eh. yung likod gusto ko stock lang yung height. pede ba 1 pair lang bilhin na spring? paplit din ba ako ng shocks nun? salamt sa input bro! peace!
Numerous lowering spring threads:
- Recommended shocks for a 2.25" lowering springs
- query on lowering springs
- suspension knocks after lowering
- TANABE NF210 vs H&R SPORT
- R-1 springs
- paputol ng springs for lowered look?
- Aftermarket (Lowering) Springs
- Lowering Spring
There are more threads by using the tsikot search engine. :D
la po kse akong making topic ng pwedeng lowering spring for corolla 93. harap lang gusto ko lopwer pwede ba 2 lang bilhin ko? sensya na ignorante pa ko sa lowering eh. papalit din aba ako ng shock? sir, baka pede ka suggest sakin ng spring at stuff na need and kung pede yung est. price nun. nabasa k kse ok yung h&r meron b ang ganun for corolla? ok lang ba kung second hand? 4 pcs ba lagi un? di pede 2 lang? slamt ng marami! God bless
Afaik, all lowering springs are sold in fours. So that means you will have extra rear coils. Unless you order them from their distributors and specify what you need.
Based from the threads that I have linked, most of them suggested change of shocks also.
Kung 4x4 at lifting procedures lang yan, mas madali sana. Ang bentahan kasi ng coils or leaf springs by pairs. :D
This might help you:
- Adjustable Coilovers
I suggest you change springs by set of fours because if you only changed the fronts and left the rear pair as stock, the car's handling will be affected (too soft in the rear). If I am correct, this might result in too much understeer.Originally posted by decipher
Since you have a 93 corolla, the shocks will be too soft for the new springs. If you are on a budget, you can use the shocks from the 98-99 corolla gli, these are stiffer than the ones in the 93 corolla.
alam ko is kyb gas shocks pati lowering springs.. dont settle with taiwan made springs like R1..
bro, pano ko kaya i rp yung harap ko taos yung likod same height lang? may idea ba kayo pano ginagawa un? gusto ko kse medyo naka subsob ng onti yung harapan. tsaka san kaya ko makakuha ng spring na 2 lang? yung para lang sa harap? yung shocks ba eh pede bilhin ng 2 lang din? pano ko setup yung oto in such a way na drop yung harap tapos yung likod same height? salamt pasensya na kung medyo hirap ko kausap! hehehe.. Thanks....God bless
What you want is what I call "Tukod look" and its not "porma"... medyo ricey pa nga iyon. And the result is the car will not be stable in high speed turns.Originally posted by decipher
My honest opinion... and your funeral if you go thru with it.
"TUKOD BABY?" - Front lower than rear ba?... subsob..... PDRF labas niyan bro.... ricey...
suggestion lang po.replace 4 pairs of lowering springs... huwag putol. already done it. naging matagtag yung ride ko...
sabi ko nga kay odell hindi ako maglolowerings dati eh. nagulat nalang nasabi ko lowerings na ko kasi di ko makayanan ang tagtag.... and katakot kasi baka dumami pa problema ko kapag putol
sensya na ignorante tlag ako.. ano ung ricey? --> yabang ba? ... nweis kse kaya medyo gusto ko ganun kse baka sumabit sya since 5 kami minsan sumasakay.. . pag lowered ba di agad lumulubog pag sinakyan? ok lang ba lowered kahit 5 isakay mo? opinions naman po mga bro... salamat . gusto ko lan maliwanagan...
