Results 1 to 10 of 15
April 23rd, 2014 11:45 PM #1
- Nov 2009
- 3,484
April 24th, 2014 01:15 AM #3
- Nov 2009
- 3,484
April 24th, 2014 01:50 AM #5Ahh..suspension lift. OME's spring, no strut spacers?
2 inch up front are usually coupled by extended shackles to level up the rear, thats the usual route. Ive heared OME leaves are stiff because they're designed for hauling, campers, trailer, etc. Body lift is the easiest and cheapest, just dont go beyond 4 inches i think, so not to make the need cracking brake lines and radiator hoses. Load sensing valve must be adjusted too.
April 24th, 2014 02:23 AM #6
If you just want to level it, lift blocks are inexpensive. Just make sure your u-bolts are long enough.
April 24th, 2014 09:44 AM #7
Yes, OME strut/coil spring combo sa front which lifted almost 3" and OME comfort shocks sa rear. The front n rear stance is now level without occupants or load on the bed. But once may sakay sa 2nd row mag tilt up na ang truck. I want the rear to be very slightly higher than the front para pag loaded mag le-level lang sya.
Nabasa ko sa australian forum meron din OME leafspring na malambot. May mga load rate sila depending on your requirement. Mahal lang nga ito na route.
April 24th, 2014 09:51 AM #8
Both way cost almost the same. I inquired a set of ironman u-bolts, they are around 2.4k + the cost of the block. Meanwhile a pair of JS extended comfort shackle from LY Autosupply cost 3.8k. Mas di matrabaho ang shackle compared to using block.
Now, I cant decide which way to go. Which of the 2 will give better ride performance?
April 24th, 2014 11:53 AM #9
U bolts sa auto supply ng kabarkada lang kami kumuha. Forgot the price. Hehe. Mura lang po.
Block will change the ride very little po. Shackles meron change talaga especially the boomerang or reverse shackle. Mas comfy daw po.
April 24th, 2014 12:15 PM #10
So,
Blocks = maging tagtag ang ride
Shackles (boomerang) = maging softer ang ride
Looking very closely at the mechanism of the boomerang shackle, may tendency na tatama ang leafspring eye sa chassis when loaded. This mechanism makes the ride softer dahil may play. Pero di yata constant ang lift kung naglalaro ang shackle compared sa stock na fixed. Tama ba analysis ko?
Di ba ma reduce ang load capacity ng boomerang shackle? Need your advice po as i want to modify the truck ASAP. Hate to see my truck tilting upwards most of the time.
Xiaomi E-Car
