Results 1 to 10 of 10
  1. #1
    Join Date
    Feb 2005
    Location
    Pasig
    Default Hydrovac Problem: To buy new, surplus, or repair
    My hydrovac is starting to give me problems. Once in a while, diretso pababa pagtapak ko sa brake. Sabi ng mekaniko hanap daw ng surplus. Is this a good solution? May nagre-repair ba ng hydrovac? Maliit lang po kasi budget ko.
    My ride is Isuzu Crosswind XTO 2001.
    Thanks to all.
  2. #2
    Join Date
    Location
    Las Pinas
    Default Re: Hydrovac Problem: To buy new, surplus, or repair
    sa akin lang, i would not scrimp if its the braking system. my life and the life of my passengers depend on it.
  3. #3
    Join Date
    Aug 2008
    [SIZE=3]My hydrovac is starting to give me problems. Once in a while, diretso pababa pagtapak ko sa brake. Sabi ng mekaniko hanap daw ng surplus. Is this a good solution? May nagre-repair ba ng hydrovac? Maliit lang po kasi budget ko.
    Thanks to all.
    [/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]Wait! Get a second opinion. Based on your description, the brake master cylinder needs a replacement kit.[/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]I hope I gave you a sound advice. Thanks.[/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]My email is practicalmechanic@gmail.com[/SIZE]
  4. #4
    Join Date
    May 2007
    Location
    Wild Wild West
    Buying surplus is buying someone else headache. Buy yourself a rebuilding kit an rebuilt it, and guarantee........ same as new.
  5. #5
    Join Date
    Jul 2003
    if there are no brake fluid leaking on your wheel brake cylinders, then most probably you have problem with the brake master cylinder. sometimes it is enough just to buy a master cylinder repair kit to fix this type of problem.
    but if the cylinder walls have dep scratches, they you have to replace the
    whole master cyclinder assembly. The hydrovac is separate/can be separated from the brake master. the failure symptom for a defective hydrovac is hard brake pedal and poor brake performance.
  6. #6
    Join Date
    Jan 2003
    Location
    Manila
    +1 on the brake master. im sure there are good brand new replacement parts for your car.
  7. #7
    Join Date
    Nov 2007
    Location
    Pasig
    Quote Originally Posted by jaydel View Post
    Thanks to all.
    i think you need to get second opinion kasi a defective hydrovac iba ang symptoms like lost brake power kahit tapakan mo ng madiin parang ayaw kumapit ng brake, matigas na ang brake pedal and pabago bago ang stiffness. ang nangyari sa iyo pagapak sa brake lumusot meaning may leak ang brake system or kailangan mo na palitan ang brake master or kung saan man may leak.
  8. #8
    Join Date
    Nov 2003
    if the master is the problem it sinks to the floor. if the hydrovac is the problem matigas sobra yung pedal. get a better mechanic imo.
  9. #9
    Join Date
    Feb 2007
    Location
    manila
    Mga sirs need help naman po, my ride is Honda esi automatic 93 model, tanong ko lang po kung ano sira ng kotse ko kung hyrovac ba o hindi. Kc parang nagleleake ang brake fluid ko bumababa sa level, tapos mag umaandar ako n medyo mabilis parang kumakadyod ang makina minsan, ano kaya sira ng kotse ko. Kc dati napalitan na ng surplus ng hydrovac ko. Eto rin kaya ang sira ngayon. tnx
  10. #10
    Join Date
    Jan 2010
    Location
    taguig city
    pa help din po.. naninikit ulet un brake ko.. kakapalit ko lng ng surplus na hydrovac last year.. kaka pa overhaul lng din ng brake ko..na brake bleed n din..last december tpos ngayon naninikit ulet.. ngayon nagpalit ako ng caliper kit.. pero kumakapit prin un brake sa left front wheel ko.. master na ba ang sira or un hydrovac ulet ??? help nmn po guys
Posting Permissions
  • You may not post replies
  • You may not edit your posts
