Results 1 to 13 of 13
    Mar 2013
    guys ask ko lng panu b increase ung rear height ng auto ko kc ang baba ng likod by the way toyota corolla 97 auto ko tnx tnx
    Jun 2010
    palagyan mo ng "sapatos" yan ang term ng mga gumagawa ng fabricated rubber bushing using pay loader tyres. mga 350 each, pa tangal mo muna saka mo dalhin sa bushingan, ganyan ginawa ko sa uneven stance ng civic ko sa rear.
    Oct 2009
    sasapian sa gawaan ng bushing swak na swak yan..
    Quote Originally Posted by dlinker View Post
    Have a "lifter" installed. It is a rubber donut that sits between the spring and shock to make it sit higher.
    Sir GH mga magkano yung ganun?
    Mar 2012
    Quote Originally Posted by d'flash View Post
    Nasa 750 yata pair tapos labor mga 400... yan pinalagay ko sa likod for the sayad/kayod issue.
    ^lifter yung tawag sakanya? or may iba pang tawag? and anong brand yung okay ipalagay?
    Feb 2009
    if you make the rear ride height higher, the caster angle turns less positive or negative making the vehicle wander from side to side. what you might consider doing is to restore to original ride height by replacing worn out bushing and tired rear coil springs. you do not try to correct a problem with another problem
    Mar 2012
    rubber lifter, generic ata yan, may sizes lang...
    if you make the rear ride height, the caster angle turns less positive or negative making the vehicle wander from side to side. what you might consider doing is to restore to original ride height by replacing worn out bushing and tired rear coil springs. you do not try to correct a problem with another problem
    Oo nga naman baka may tama na shocks mo kaya mababa na ride. pasilip mo muna.
    Last time I had it done was P500 each and another P400-P500 for install for each corner.
    Mar 2013
    Good day sir,
    paano ba malalaman kung palitin na? last time check ko shock absorber ala naman tagas shock absorber, ok pa rin naman bushing. spring kaya?
    may idea po ba magkano at ano recommend na brand for spring and shock.
    btw corolla bigbody 96 model po.
    TIA
    Aug 2013
    Quote Originally Posted by gabygab View Post
    Good day sir,
    TIA
    kadalasan shocks ang nasisira, bihirang bihira masira ang coil springs, depende na lang kung na expose ito sa extreme heat or naputulan na.
    replacement springs na nagamit ko HTK brand, mga 800 to 1000 pesos ang isa. sa shocks naman, KYB pa din, mahal siya pero good quality, kung medyo low budget for shocks, hanap ka Sprinter o kaya Optimum brand, tumatagal sa mga corolla, tapos ipon na lang para sa KYB kapag nasira na.
    everytime na may gagalawin ka sa suspension mo, kailangan mong magpa wheel alignment (Camber and Toe alignment).
    Apr 2010
    pinagawa ko yung tsikot ko (2000 model Mazda 323) sa Zee Carplus and had its rear raised. nahirapan at first yung mga mekaniko tanggalin yung assembly ng rear shocks but eventually natanggal nila ito. I decided not to replace them yet (since wala pang budget to replace the rear shocks) and have it repaired and they filled it with nitrogen (?) para tumigas yung shocks. total damage sa repair: P2700.
    medyo nanibago ako sa pagdrive after the repair but I adjusted the driver's seat position para mas comfortable ako sa pagdadrive
    tapos inibiyahe ko siya with 5 people inside (me included) going to Infanta, Quezon and encountering some uneven road surfaces. good thing na hindi na siya sumasayad yung kotse after the repair unlike before, sumasabit pa siya.
how to increase rear car height?
