Results 1 to 2 of 2
  1. #1
    Join Date
    Sep 2010
    Default Help po Pricing for Kalampag Repair
    Good day to all Advisors,
    Sir my car is Toyota XL 94.
    I've observed kalampag (tok tok lagatuk) noise especially in the driver's seat area, not much in the front passenger's seat. Lumalakas lalo kapag sa daang di pa aspaltadu. Inuna ko kasi muna mga works sa engine side ng car, kaya now ko lang bibigyang pansin ang matagal ng "tok tok",hehe!
    i have read from other topics that possible to checks are the following:
    1. Ball Joint
    2. CV Joint
    3. Bearing
    4. Bushing( rack & pinion )
    5. Rack end
    6. Tie rod
    Papatulong lang sana ako with the pricing, suspecting one or more in the list needs to be repaired or replace. para lang po prepared ako financially kapag dinala ko na sa talyer.
    Thank you!
  2. #2
    Join Date
    May 2011
    Default Re: Help po Pricing for Kalampag Repair
    eto brother ang may pinakamura at well experienced na underchassis shop
    check the link so you can see the map and their prices, FREE ESTIMATE AND CHECK UP SA KANILA
    http://www.sulit.com.ph/index.php/vi...+SPECIALIST%29
Posting Permissions
  • You may not post replies
  • You may not edit your posts
