Results 281 to 290 of 291
November 23rd, 2013 12:28 AM #281
last June nanduon ako sa kanila, nagpapalit din ng shock mount. mura yung labor. 350/side = 700. tapos tumawad ako binigay ng 650.
dyan din ako nagpakabit ng shocks dati, hanggang ngayon ok pa naman yung takbo saka sa kanila na ako bumili ng shocks para na din sa warranty madali iclaim kung sakali may defect.
- Aug 2013
- 112
December 14th, 2013 08:45 PM #282Hi guys! Hows ur experience with zee and cruven lately? Papatingin ako ng ilalim ko sana. I think zee is getting more vote here. Any other suggested shops?
Sent from my H100 using Tsikot Car Forums mobile app
- Sep 2011
- 37
December 19th, 2013 08:41 AM #283Mga boss bukod sa cruven or zee san may magaling na shop na open pag sunday? Marikina or commonwealth qc area? Thanks
December 29th, 2013 01:48 PM #284
I went to cruven crame a few months back to get my 93 civic's suspension serviced. Ok naman no problems whatsoever. Would go back again if needed.
Sent from my GT-I9300 using Tapatalk
- Oct 2009
- 179
December 31st, 2013 10:56 AM #285Mga sir nag rerebuild ba ng stabilzer bushing sa cruven? Sa zee kasi hindi daw.
January 7th, 2014 01:35 PM #286
- Oct 2009
- 179
January 8th, 2014 11:02 PM #287
- Aug 2013
- 112
January 30th, 2014 12:26 AM #288I had my ilalim repaired by wheelers last week. And they did a very good job! Tanggal lahat ng kalampag at tagtag ng sasakyan ko (galant 7g). Smooth ride na. Dami nga lang pinalitan... shocks, stab link, bearing etc. They're honest peeps and tell you kung ok pa o hindi na, kung replace or repair. *clapclap*
Kaso may problema ako... walang avalaible na bushings for my upper suspension arms, as in naghanap yung parts guy nila sa bong banawe! I called el dorado and wala rin sila bushings, buong assembly lang daw where the OEM costs a whopping 7.8k and replacement for 1.4k.
So ngayon, what wheelers did is just do a quick fix for the worn out bushings muna. Sapi ata tawag nila dun. But then temporary fix nga lang daw. And i'll have to replace the bushings soon. The thing is maayos pa mga suspension arms ko kaya nanghihinayang ako magpalit.
Right now I'm thinking of bringing it to cruven fairvew since it's less than a kilometer away lang yun samin. And just have a poly bushing fabricated nalang. Sabi nila the ride will be a little stiffer, but then kesa naman buong assembly naman bilhin ko.
May mga gumagamit naba ng poly bushings sainyo dito? kamusta naman?
January 30th, 2014 02:21 PM #289
saan po ba yung location ng cruven at Zee? specialists ba sila sa suspension/shocks?
January 31st, 2014 11:05 AM #290
Suzuki JIMNY [merged threads]
