Yung Maxxis 195/55/15 namin 3200 each namin nakuha sa Blumentritt kaso 2010 pa ata production. Bwisit.Mura talaga sa Blumentritt kaso ingat lang. Nawala sa isip ko production date kainis. Low mileage pa naman yung oto at hindi masyadong nagagamit.
OT lang:
Anong difference ng tire na rotational sa hindi? Sorry noob question.
Rotational tires are tires that must rotate in a single direction.
This means that you'll have to rotate the tires front and back instead of the normal left-right-diagonal pattern.
May napansin ako though. Dun sa Ecsta, walang nakalagay kung aling sidewall ang inside at alin ang outside. Does this mean that, for example, I wanna exchange my rear tires, can I take out the rim then mount it facing the opposite sidewall so I can do the aforementioned switch?
Now that you mention it, possible din *ATA* unless there are additional markings on the other side.
Rotational direction lang ata meron sa Ecsta, if I'm not mistaken. Plus the tires seem symmetrical from left to right.
*mda the store's name was tirecenter.com.ph may align equipment din sila. Any inputs? Do they sell cheap? I only know a few tire shops eh. Sa SnR nagtanong ako sobrang mahal dun.
Sir renz, nasa sidwall yan. It's a 4 digit number.
In this case, it's 4202 - manufactured on the 42nd week of 2002. Some of the more aggressive tire shops recommend a 5 year replacement cycle, but I think you can push it somewhere closer to 10 as long as you don't abuse the tire. Sa Camry namin umabot naman 9 without problems (before we replaced the whole set of 4)
Honestly sir, I'm not so sure.
I would recommend Bridgestone Makati (although mahal ang gulong). For Yokohama, there are a list of dealers on their local webpage you can canvas from. For Kumho tires you can look up Roadstar Fort/Makati.
Kakabili ko lang ng gulong sa evangelista makati. Miller tires ent. 3742112. Free alignment and balancing. Yokohama binili ko. July 2012 manufacturing date ng gulong. Btw nabasa ko na after 5years prone na to blow out ba tawag dun yung gulong. So it's up to you kung malakas loob mo saka mahal mo pa buhay mo at buhay ng family mo na nakasakay sa kotse mo hehe
Hehe actually, in light of the recent updates sa thread, pwede mo ring imount sa kabilang side yung tire. Pero you can't just remove the rim/tire and mount it on the other side. Kelangan pa i unmount/remount so that the rim is reversed but the tire is still facing the correct direction. This is unless the tire is also asymmetric from left/right, meaning dapat may side na laging facing outwards.
sir. do you have any idea how much is the brand DUNLOP GRANDTREK A20 AT? 255/70 r16. i search the net wala ako nakita
