Re: break tumitigas minsan
To check if the hydrovac is working, step on the brake while engine is off. Start the engine, the brake pedal should sink a bit since vacuum will energize the hydrovac. If the pedal does not sink, there is possibly problem sa hydrovac - check for broken vacuum hoses. If the pedal sinks, have the brake master cylinder checked.
I assume that original pa yung hydrovac and yung master cylinder has not yet been replaced. Sometimes kasi mayroon mismatch itong dalawa kung pinalitan.
Also check the inline brake valve sa vacuum hose ng hydrovac. Baka barado or stuck open na (loses vacuum on WOT).
Quote:
Originally Posted by
basucat
I just test it using the procedure you gave.
I can say now the culprit is hydrovac. upon start the pedal did not sink. the brake master cylinder still working fine.
and beside, that is the finding of my mechanic. without telling him the parts that cause the problem. just told him what the issue all about
Anung car mo bro, bago ba yung 3000 petot japan na hydrovac? ok din naman kahit surplus japan
