pagka drum brake ba harap at likod at hindi hydrovac ang brakes mo ay natural lang na di bomba? 2 times ko kasi kailangan tapakan un brake bago kumagat. thanks.
Printable View
if the system were a matched system, you should not need to pump the brakes. sure the brake pedal effort required is greater and the stopping distance longer but the pedal travel should be within one inch from fully released unless the brake shoe to drum clearances are too wide. try adjusting the brake shoes manually first by tightening the starwheel adjusters and back off one turn of the adjuster. what vehicle is this on? a vintage '30's car? why not retrofit to disc/drum or 4 wheel disc brakes
