Results 1 to 5 of 5
- Jan 2010
- 31
January 11th, 2010 02:27 PM #1hi, p help nmn po.. AT po un car ko honda civic.. nag iistack up kc un brake!!.. kaka pa overhaul ko lng.. nag change narin ng caliper kit. pero naninikit prin.. na brake bleeding nrin pero ganon prin.. mbilis uminit un left front wheel. ok din nmn un brake pad ko.. kaka palit lng din ng hydrovac ko last year..
sabi sa sa talyer. baka daw un master cylinder n un cra.. magkano po kaya at saan mganda bumili nito???
any suggestions po... thx..
January 11th, 2010 02:51 PM #2
the vacumm brake booster is not at fault here. if it were, it would be all four brake ends having a problem. the problem is probably the brake hose on the left front assuming the last sonofagun who did this did the calipers right. if the brake booster push rod length was too long, it would cause all four brakes to drag. come on now, let us use some common sense and don't go back to that shop
January 11th, 2010 03:01 PM #3
- Jan 2010
- 31
- Jan 2010
- 31
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
