Hi mga sir need advice Lang my brakes are making a metallic sound na parang wet ang brakes even after uminit na ang brakes n car, n if run to a speed of 60kph above when I step on the brake my thud sound na tumutunog mostly sa front passenger side.this happen after crossing flooded waters last week aside from the noisy brakes ok pa naman lahat brakes are working fine malakas ang kapit.
Na pa linis ko na din yung brake pad n rotor, also just change to new pads last month n flush my brake fluid before the flood.
Got my bendix from LVC in banawe, malapit sa KFC. May post sila sa sulit for the prices.
question i have a toyota vios which is front wheel drive/ fron disc rear drum...
now i noticed some drag when i cruise with it... so what i did was with the hand break dis-engaged i jack up one of the rear tire at a time and spin it, one was spinning freely (driver side) and one was hardly spinning (passenger side)
what shall i do, i plan to remove the drum and see if it would spin freely...
i had my brake pads replace with bosch. cost me P700. ok naman, tahimik.
