Results 21 to 40 of 42
    Feb 2011
    #21
    Kung Dot3 lang, the Shell dot3 is good enough. Mura pa P220 for 1 liter. And shell stations can do bleeding plus aircleaning, sandpaper-ing of brake calipers and pads.
    #22
    Quote Originally Posted by fitdrive View Post
    Sa shell before, vacuum lang ginawa from the brake fluid reservoir. I didnt know na pwede pala sila mag bleed.
    Oct 2011
    #23
    Mura na yan sir. Ung Prestone nasa Php309/Li....
    Sep 2010
    #24
    pasawsaw -
    so yun Brand A pwedeng ipang-topup
    sa Brand B na gamit nung oto basta pareho silang DOT3?
    tia.
    Oct 2011
    #25
    of course sir.
    Feb 2011
    #26
    Yes they do sir. Yun bomba method. I did it twice with them na with 2 cars. Basta dapat mechanic din yun nag-bomba ng preno. One time kasi, medyo late na ako nakapag-servicem after office, walang makuha mechanic yun mekaniko ko to pump the brakes, ang kinuha yun shell helper na teenager na may neon vest, sobrang tamad nun bata. Ayun lumulusot yun preno, may hangin pala. Pero next day naman, they corrected it.
    Yun vacuum method is if you ask them to replace brake fluid, as what the Casa do. Get the full service, change brake fluid + plus bleeding, check and clean brake pads and calipers (this is using sandpaper and machine grinder for the pads, and aircleaning of brake components using compressed air after. Medyo mahal lang P220 (brake fluid) + 180 per tire or P720.
    Yun casa kse they have this service brake pad cleaning sevice every PMS, around P150- P250 using brake cleaner spray. Walang kwenta yun, it will have effect for 2 weeks, medyo kapit preno tapos pag-nag dry na cleaner spray or maybe after a car wash at na-sprayan ang brake calipers. Rotors and pads, wala na kasi andyan na oxidation / rust
    Oct 2011
    #27
    Petron brake fluid retails for Php96/250ml fyi.
    Aug 2013
    #28
    Went to a shell station last weekend to have my engine oil and filter changed, ATF replacement, and brake fluid replacement via bleeding. They did the oil change using shell oil and vic filter, and replaced ATF using the fluid I purchased from Toyota.
    However they suggested that I just perform the brake fluid replacement using a syringe that can be bought from mercury drug then do the top-up using any DOT3 brake fluid. Anyone here who have successfully done this? Are there any risk?
    Jan 2008
    #29
    Quote Originally Posted by dos2 View Post
    I bought brake bleed tool from lazada for 1200 pesos. It comes with a manual vacuum pump, containers and tubes.. i replaced my brake fluid using that tool... no need to manually pump the brake. Just make sure to fill up every time you bleed. Start from the farthest wheel from the brake reservoir
    Aug 2013
    #30
    How does that work? I mean, do you need to remove the tires or it is just attached to the brake fluid reservoir? Thanks
    Apr 2018
    #31
    suggest ko just let the pms gas stations do it, for brake bleeding and replacement would not cost php250, well worth it plus brake fluid cost of less than 300
    Aug 2013
    #32
    Quote Originally Posted by litocamayo91 View Post
    Honestly, if i do not get a confirmation here who have successfully done this using the syringe method, baka isabay ko nalang yung brake fluid bleeding sa next pms ko (after 5K kms) tutal ipapa brake cleaning ko na rin tsaka wheel rotation.
    Jan 2008
    #33
    What i did is to completely evacuate the system of the old fluid.. then replace with fresh fluid (changed to DOT4). Removed tires and pump out fluid from bleed valve using the brake line bleed tool.
    You can buy the tool and ask your mechanic to do it. Or do the old the tested trick.. pump-hard press-release
    Aug 2013
    #34
    Thanks for sharing
    #35
    That method doesn't fully flush the system.
    If you're in the QC area and Banawe is accessible, i used to have my brake fluid flushing done at Wheelers Suspension Haus along N. Roxas St. They have a brake dialysis tool that can suck the system clean.
    Aug 2013
    #36
    Unfortunately I live in Calamba, and as far as I have read in this forum, can't find a shop nearby that offers brake dialysis.
    May 2016
    #37
    #38
    Better let the professionals do brake bleeding. A mistake doing this task can lead to death or injury. No kidding.
    Me i am a DIY mechanic but when it comes to things like this id rather pay to have it done correctly.
    Dec 2017
    #39
    I asked the help of a mechanic to replace the brake pads. Unfortunately, we had a good chat that both of us forgot about the level of the brake fluid. In other words, the fluid spilled.
    What I did is, I poured water here:
    I was hoping that water will travel slowly all the way where the fluid spilled. Then later, I decided to use a hose to water everything besides it.
    Did I do the right thing?
    #40
    washing spilled brake fluid with lots and lots water, is the right thing to do.
    brake fluid acts as a paint stripper. get all of it out by using lots of water.
    but be careful that you do not force it into the clutch and/or brake fluid reservoir, and you do not get it onto sensitive electrical parts. be mindful of the pressure.
    sabi nga ni hancock, "good job!".
Brake Fluid
