Results 1 to 10 of 42
April 19th, 2013 12:14 AM #1
Is it advisable to use imported brake fluids such as Bendix or Mag1? compared to local brands like National or Super Brake perhaps? Ano ba advantage of using imported brands mas tumatagal ba? TIA.
April 19th, 2013 10:04 PM #3
okay sir, same DOT3. malaki rin kasi ang price difference, ung Mag 1 na 1L nasa Php470 samantalang Php180 lang ung sa Super Brake.... Kaya ko natanong kung may advantage ba using imported brake fluid kasi every 2years naman standard pag palit....
May 3rd, 2013 04:02 PM #4
Bro retz, pinapalitan ngayon brake fluid ng sasakyan ko. Nakalagay sa lalagyan DOT3 only pero DOT4 ang pinalagay ko. Ang tatak is Johnsen's. Ok lang kaya yun?
May 3rd, 2013 04:43 PM #6
May 3rd, 2013 04:57 PM #7
Use brake fluid that is recommended by vehicle manufacturers. Do not mix brake fluid with different DOT ratings, unless in an emergency situation, example: Nawalan ka ng preno sa Tagaytay, your car needs DOT 4 brake fluid, pero DOT 3 lang available. You can use DOT 3, if just to drive your car home. Then bleed and replace with approved/correct brake fluid. Nangyari na sa akin yan.
See link re: DOT ratings; Brake FluidLast edited by lowslowbenz; May 3rd, 2013 at 05:00 PM.
May 3rd, 2013 05:29 PM #8
May 3rd, 2013 05:49 PM #9
May 3rd, 2013 06:08 PM #10
The backup charger finally arrived. Here are my findings and conclusion at the end:
