Results 1 to 10 of 19
- Oct 2009
- 179
October 25th, 2014 07:31 PM #1help mga sirs, un isang bolt ng mags hindi na matangal nabilog na, ang masama pa nito sininsil ng nagvuvulcanize sa petron, anong remedy at saan ko ito dadalin? nagtry na ako sa welding shop papainitan ko sana pero hindi din kaya. first time ko patangal un mags, magpapalit na kasi ako ng tires. thanks.
- Oct 2009
- 179
- 52,684
October 25th, 2014 07:35 PM #3bolt chaser... you might also try attacking it from the other side.
kayah yan.. kailangan lang ng isang marunong gumawa.
October 25th, 2014 08:09 PM #4
Bolt o nut? Baka nut, yung iniikot. Yung bolt nakatanim sa axle yun
Sa machine shop mo ipatanggal. Baka mabasag mags mo sa ibang talyer
Posted via Tsikot Mobile App
- 52,684
October 25th, 2014 08:13 PM #5
October 25th, 2014 08:57 PM #6
Been doin' this a coupla times by drilling the bolt first with a small bit for a pilot hole. I drill that bolt a bigger bit by sixteenth of an inch until the drill bit is as big as the stud bolt or when the stripped lug nut falls off
Posted through phlpost.gov.ph
October 25th, 2014 09:38 PM #7
Picture nga ng problemang yan. Di ko ma imagine bakit namilog eh ang tigas nyan
- Oct 2009
- 179
October 26th, 2014 12:45 PM #8eto na po pictures. nut lang po talaga ang nakalagay.
http://tsikot.com/forums/newattachment.php?values[t]=99840&contenttypeid=1&poststarttime=1414294911&po sthash=b2bb7a55ae39713630745a135791ee0c
October 26th, 2014 01:02 PM #9
There are socket wrenches to remove lug nuts like this. One type has a tapered or pipe thread in counter clockwise rotation to engage at the same time it is unscrewing the nut. What is commonly available procedure is a power drill and a set of drill bits. Do not use hammer and chisel, it will have more collateral damage than progress
October 26th, 2014 02:48 PM #10
try mo ito TS:
lagyan / sprayan mo ng WD40 'yung nut. let it stand for a couple o' minutes.
hayaan mong pumasok ng husto doon sa loob ng threads.
after say about 15mins (preferably longer), get a VISE GRIP TOOL. 'yung LONG NOSE type.
ipitin mo 'yung nut. make sure na mahigpit ang kapit, baka kasi kumalas/bumitaw
eh madisgrasya ka pa. SAFETY FIRST.
maipihit mo lang ng konti 'yan, kahit quater turn lang, maaalis na 'yan.
tama si sir Newcomer123. ang bolt niyan eh nakatanim sa axle.
may thread/ipin 'yung bolt (parang gears) na naka- kagat naman sa axle na may thread din.
kaya pag ni- pihit mo 'yang nut, hindi sumasabay 'yung bolt.
kung sakaling maalis mo, palitan mo na ng bagong nut/lugs and bolt.
mura lang naman 'yan sa mga auto shops. good luck.Last edited by joemarski; October 26th, 2014 at 02:50 PM.
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
