Page 40 of 76 FirstFirst ... 3036373839404142434450 ... LastLast
Results 781 to 800 of 1510
    Aug 2004
    #781
    san kaya merong available na firenza tires (215/45r17)?
    #782
    Quote Originally Posted by chyll2 View Post
    just did an initial google :D
    yokohama S drive
    hankook ventus v12 evo K110
    Kumho ECSTA SPT
    which of these would you prefer? size I will choose is 215/45/R17 (since konti lang nag offer ng 205/50/R17)
    I will only be buying a pair, then replace the other tires as well when the other two needs replacing as well.
    Mahal pareho yung S.Drive and Ventus. The S.Drive would cost you almost double what an Ecsta SPT would cost you.
    I have Ecstas on our Altis. 205/55 R16 costs 4.1k a piece. For your car, siguro mga 5k. An equivalent S.Drive would probably cost around 9k.
    Aug 2004
    #783
    how's the performance of Kumho ECSTA compare to Federal 595 EVO?
    i'm looking for a reliable 215/45R17 for our Altis.
    thanks.
    Jan 2008
    #784
    no experience with them but both will do just fine. Just stay away from SS595 as they are very very noisy (my brother uses a set)
    #785
    Hi all,
    Magpapalit na kami ng tires on our FD Civic - 205/55/R16 91V
    OEMs are Bridgestone Turanza ER30s.
    What I didn't like about these was that they made quite harsh and noisy.
    What are good budget tires for replacement?
    The initial shortlist
    Bridgestone Turanza ER30 - P7200
    - quiet on asphalt, noisy on cement, harsh ride
    Yokohama A. Drive - P5300
    - quiet on asphalt, (not as) noisy on cement, ride is less harsh
    Kumho Ecsta KU31 - WHERE AND HOW MUCH?
    - how are these tires?
    - **reviews seem to indicate that this is quite a good tire. Value for money, good grip, but wears a bit fast and gets much noisier when wearing out. Not a lot of info about comfort though.
    - I'm interested in these
    Kumho Solus KH17 - WHERE AND HOW MUCH?
    - **reviews seem to pan these tires.
    Dunlop 703 - P4800
    - don't think I want these, bumubukol and bad grip. But I'm just writing it down here.
    Any other tires I should be considering? Want something comfortable, quiet with reasonable grip. Hindi naman kami nangangarera sa daan haha.
    Also, I don't think I'd like to consider chinese brands at the moment. Want something at least at par with OEM quality.
    Feb 2012
    #786
    i'm good with my yoko a.drive. as you said nga and i can confirm, quiet on asphalt and not so noisy on cement. sa umpisa parang medyo maingay, pero siguro nasanay lang ako sa yoko stock tires. ngayon okay na. parati lang dami nakasingit na mga bato sa tire tread.
    #787
    Yup tama, (pati yung bato sa tire tread) actually yun yung stock tires namin sa '09 Civic namin. So far It feels better than the Bridgestone ER30s on the '06. Just checking if there are other tires that may be better value for the money.
    So far, parang okay yung Kumho Ecsta KU31. Just looking for a dealer and other people's feedback. Halos 500PHP cheaper per tire e. (Just got off the phone with a shop that carries them)
    #788
    My experience with Kumho tires is their thread tend to wear quite readily.
    #789
    Quote Originally Posted by Gerbo View Post
    So how fast has your tread worn sir?
    Our Civic's OEM Turanza ER30 has already worn out (less than 2mm left) with more or less 37K KMs.
    Aug 2006
    #790
    Goodyear Assurance Armorgrip is quite a good all around tire. It's grippier, more comfortable and quiet than Goodyear Duraplus though it wears out faster.
    Hankook Optimo K415 is a nice tire as well. Not as quiet as the K715 but has better grip.
    Try to look around and get some quotations for Bridgestone Turanza GR90 as well.
    #791
    Any idea where to get?
    The GR90s are bloody expensive and are front/back tires. Gonna be kind of expensive to replace.
    Aug 2006
    #792
    Tirecenter is a good place to start for Hankooks and Bridgestones. They also carry Continental Comfort Contact 5 but they're order basis, costs 5.6-5.8k for the size you mentioned.
    Goodyear Assurance is 5.3-5.5k in Servitek branches.
    Aug 2006
    #793
    Aug 2006
    #794
    Tirecenter is a good place to canvass. They have the Continental Comfort Contact 5 that costs 5.7-5.8k. The Goodyear Assurance is roughly around 5.3-5.5k in Servitek branches.
    Jun 2006
    #795
    I drive a 2009 Honda City with stock mags. Tire size 175/65R15 I want to use the stock mags but upgrade to a wider tire. Mostly highway driving. I want comfort and quiet tires. I find the stock Goodyear GT3 to be too thin. I think upgrading to wider tires will give better grip.
    According to tire size claculator I can use:
    1. 195/55R15 its 2.1% smaller. Meaning the car will be droped by a .6 inches. I'm a bit concerned bec my drive way is high and my car's underside sometimes hits when backing out. This is .8 inches wider.
    2. 195/60R15 is 1.1% larger. Its .2 inches taller and .8 inches wider. Will it look like a balloon?
    3. 205/55R15 is 0.3% smaller which is almost exactly the same height .1 inch smaller, while being 1.2 inches wider. Will fit the stock mags or its too wide?
    #796
    Quote Originally Posted by userfriendly View Post
    Finding 205/55R15's will be a bit hard but its worth the try. If not, go with the 195/60R15s.
    Oct 2008
    #797
    sir, the best upgrade for your city in my humble opinion is 185/65 R15.
    Jun 2006
    #798
    Quote Originally Posted by ryce View Post
    parang ok ang 185/65r15 .5 inch taller and .4 inchwider. So its a little taller and wider. Hopefully the additional height is enough so I dont scrape my bottom in my driveway. What brands are good? I'm thinking:
    Yoko C drive 2, goodyear nct5, Toyo Teo Plus, or Bridgestone. Dont like Dunlop. Not interested in Fedral, Gt, Nangkang and China brands.
    #799
    ^You can always test mount on your chosen sizes at the shop before deciding with finality.
    #800
    hi guys,
    May nakagamit na ba ng Maxxis tires sa inyo? Ano masasabi nyo sa performance in terms of grip on wet and dry roads, noise, durability, price and sidewall protector? Saan nga ba gawa ito?
    Thanks
The Best Brand of Tires
