Results 1 to 4 of 4
    Aug 2011
    mga sir ask ko lang kung pwede ba ang 175/50/13 tire sa 13x8 na mags ayos lang ba o delikado?
    price nila ang Fulda 2,300 and Yokohama 4,100
    Feb 2009
    Quote Originally Posted by oca_doc View Post
    this proposition is dangerous. your tire width is only 6.889 inches and your wheel is 8 inches. the tire bead might not hold air and if it does, it is dangerous when you make turns with thrust loads applied to the sidewall of the tire
    Aug 2011
    thanks sir jick.cejoco, any suggestion what tire il use, 205/60/13 gamit ko ngayon sa 13x8 na mags na kakapalan pa ko.
    Feb 2009
    205 mm is about 8.07 inches. this width is okay to use with 8 inch wide wheels. you may drop the profile but check that your powertrain can be reprogrammed with the new overall diameter tire. if you have non computer controlled transmission, it might be okay. 205/50R15 is a tad too large and 205/50R14 is a little bit too small of a diameter for a replacement for what you have now
175/50/13
